Problem with setRoundFirstLabel
Dmitry
Post by Dmitry » Fri Jul 31, 2009 2:03 pm
                chart.getAxes().getBottom().getLabels().setDateTimeFormat("d hh:mm");
		chart.getAxes().getBottom().setIncrement(Utils.getDateTimeStep(DateTimeStep.ONEDAY));
		chart.getAxes().getBottom().getTitle().setText("Date");
		chart.getAxes().getBottom().getLabels().setRoundFirstLabel(true);
		chart.getAxes().getBottom().setStartPosition(1);
                        com.steema.teechart.DateTime cd1 = new com.steema.teechart.DateTime(c1.getTime().getTime());
			com.steema.teechart.DateTime cd2 = new com.steema.teechart.DateTime(c2.getTime().getTime());
			chart.getAxes().getBottom().setMinMax(cd1, cd2);
c1 - 00:00:00 first date interval
c2 - 23:59:59 last date interval
My timezone +3h
I had like set axis line to 00:00
Sorry my English
Dmitry
Re: Problem with setRoundFirstLabel
Post by Yeray » Fri Jul 31, 2009 2:56 pm
Hi Demetrio,
Yes, it seems that the hour is not rounded or calculated correctly. So I've added this to the wish list to be fixed in future releases.
In the meanwhile you could force the 00:00 time to be shown as follows:
chart.getAxes().getBottom().getLabels().setDateTimeFormat("d 00:00");
Dmitry
Post by Dmitry » Fri Jul 31, 2009 3:40 pm
Set chart.getAxes().getBottom().getLabels().setDateTimeFormat("d 00:00"); is not correctly.
Just you changed label but not axis. I'l like that FIRST axis set to 00:00 and next... next... next
I use area chart with series.setStairs(true); and I set left border to 00:00:00(N - value) and right border 23:59:59( 0 - value) for my histogram
						com.steema.teechart.DateTime dd = new com.steema.teechart.DateTime(cStart.getTime().getTime());
						series.add(dd, value);
						dd = new com.steema.teechart.DateTime(cRight.getTime().getTime());
						series.add(dd, 0);
Dmitry
Post by Dmitry » Fri Jul 31, 2009 5:48 pm
How can I set first Label for DateTime axis?
Dmitry
Post by Dmitry » Sun Aug 02, 2009 4:52 pm
I've decided my problem so TimeZone.setDefault(TimeZone.getTimeZone("GMT+0"));
I'm waiting your bug fix.
Best regards
Dmitry
Post by Yeray » Tue Aug 04, 2009 10:30 am
Hi Dmitry,
I'm not sure to understand your problem. Is it possible that you are looking for SetMinMax axis function?
If not, could you please attach a simple example project we can run as-is to reproduce the problem here?
Dmitry
Post by Dmitry » Tue Aug 04, 2009 1:10 pm
Yes I use function setMinMax(c1, c2) c1=00:00:00 c2=23:59:59
if set setRoundFirstLabel = true first vertical axis is 4:00:00 ( for my GMT +3)
if i set GMT+0 first vertical axis is 00:00:00 ( correct for me)
Post by Yeray » Tue Aug 04, 2009 1:41 pm
Hi Dmitry,
Then I'm afraid that you probably should translate your dates to GMT+0 before using them as dates.
