Small bug in Linux
Dmitry
Small bug in Linux
Post by Dmitry » Sat Sep 05, 2009 5:14 pm
Re: Small bug in Linux
Post by Narcís » Mon Sep 07, 2009 8:15 am
Hi Dmitry,
Does this only happen in Linux machines? Have you been able to consistently reproduce this in different computers? With which TeeChart, Java Runtime Environment, development environment and Linux versions occurs?
Dmitry
Post by Dmitry » Mon Sep 07, 2009 10:24 am
Linux linux19 2.6.25.20-0.5-pae #1 SMP 2009-08-14 01:48:11 +0200 i686 i686 i386 GNU/Linux
OpenSuse 11.0
java version "1.6.0_15"
Java(TM) SE Runtime Environment (build 1.6.0_15-b03)
Java HotSpot(TM) Client VM (build 14.1-b02, mixed mode)
version TeeChart?
TeeChart for Java Build 2.0.0.801 (SWT)
Post by Narcís » Mon Sep 07, 2009 10:29 am
Hi Dmitry,
Thanks for the info. I forgot to ask you how axes titles text is being added.
Dmitry
Post by Dmitry » Tue Sep 08, 2009 1:36 pm
And I forgot to say you that strange symbol appear in other title ( chart.getChart().getTitle().setText("Disk pool usage");)
I set title so
chart.getAxes().getLeft().getTitle().setText("% Utilization");
Just do it
Post by Marc » Wed Sep 16, 2009 2:18 pm
Your code doesn't provoke the error when tested on Windows. We'll run the test on Linux too. In the meantime, your image shows Chart headers 'BACKUP - ALL' and 'ARCHIVE - ALL'. Those titles don't display the problem; how are those titles set that differs from the problem you find via the code 'chart.getChart().getTitle().setText("Disk pool usage");' ? Are you using a different code line?
With thanks.
Dmitry
Post by Dmitry » Fri Sep 25, 2009 7:51 am
Strange symbols appear again but on Windows System
SWT version is version 3.550
Post by Narcís » Fri Sep 25, 2009 8:46 am
Hi Dmitry,
We can not reproduce this in Windows and Swing project with Netbeans in Linux. We are also testing SWT in Eclipse and Linux.
BTW: Do you use any specific code for setting those strings?
Dmitry
Post by Dmitry » Fri Sep 25, 2009 11:21 am
Attention.
I changed swt library to new 3.550 and strange symbols appeared at once.
Post by Marc » Fri Sep 25, 2009 2:42 pm
We've installed swt 3.550 and repeated tests. We're not seeing the error here. We may have missed something, are you able to send us a small sample project that reproduces the error? The error appears as if an extra character is adding itself to the line at some stage, a new-line or carriage return for example.
With thanks.
Dmitry
Post by Dmitry » Mon Sep 28, 2009 1:18 pm
I started your example from source. Strange symbol is too.
swt 3.5
Post by Marc » Mon Sep 28, 2009 3:08 pm
If you run the TeeChart examples from the compiled swt example folder, do you see the same error?
Dmitry
Post by Dmitry » Mon Sep 28, 2009 3:24 pm
I used your source code and compiled with new swt.
If run compiled swt example(TeeChart.SWT.Features.jar) result is normal without strange symbols
