Exporting Date with Excel
Guilz
Post by Guilz » Tue Sep 29, 2009 9:30 am
Questions about exporting date with Teechart Pro 7.0:
If I export my Teechart chart data with
.Export.asXLS
My date are not showing correct format
Now, If I export data with following code
.Export.asText
My date are in correct format but when Excel is launching I've the following alert message:
So, what is the best way to export to excel data whith date ?
Is Teechart Pro 8.0 displaying date correctly when exporting to excel ?
Thanks a lot for your help
Guilz
Re: Exporting Date with Excel
Post by Narcís » Tue Sep 29, 2009 11:29 am
Hi Guilz,
The same problem and solution were described here.
Guilz
Post by Guilz » Tue Sep 29, 2009 12:55 pm
Narcís wrote:Hi Guilz,
Thanks Narcis - I had already read this topic before posting...
I don't think we can speak about solution if we must reopen Excel file after each export and set each datetime column as datetime field instead of general field type :?
Guilz
Post by Yeray » Tue Sep 29, 2009 1:50 pm
Hi Guilz,
I'm not getting any error with the following code in TeeChart AX v8 and Office 2003. Could you please try if it works fine for you?
Private Sub Form_Load()
  TChart1.Aspect.View3D = False
  TChart1.AddSeries scLine
  TChart1.Series(0).XValues.DateTime = True
  Dim month, year, i As Integer
  i = 0
  For year = 2003 To 2009
    For month = 1 To 12
      TChart1.Series(0).AddXY DateValue("1/" & Str$(month) & "/" & Str$(year)), Sin(i / 10), "", clTeeColor
      i = i + 1
    Next month
  Next year
  TChart1.Export.asText.SaveToFile "C:\tmp\test.xls"
End Sub
Guilz
Post by Guilz » Tue Sep 29, 2009 2:00 pm
Yeray,
I confirm - This Excel Messagebox appear only with Office 2007.
We don"t have this issue with previous version of Excel.
Guilz
Post by Yeray » Thu Oct 01, 2009 9:29 am
Hi Guilz,
Yes, I've verified that this error appears in office 2007.
So, as you've seen there are two possibilities:
- asXLS: works without any error at all. But, as Narcís explained, as delphi saves the numbers as doubles, you'll see doubles instead of dates in the first column. And then you can set this column to Date format in Excel.
- asText: gives a format error in Office 2007 but it still opens the file and displays all the columns as you had them in TeeChart as it saves the strings.
Guilz
Post by Guilz » Thu Oct 01, 2009 9:48 am
Right - both are not fantastic :twisted:
I will try to use the second one and before opening the Excel file use excel.Application object and save it as true xls with DisplayMessage = false...Not cool to patch the asText method because asXLS method does not work...
Good idea to do something in Teechart v9 no ? :wink:
Guilz
Post by Yeray » Fri Oct 02, 2009 9:45 am
Hi Guilz,
Yes, I've added this to the wish list to be revised in future releases (TV52014461).
Guilz
Post by Guilz » Fri Oct 02, 2009 10:30 am
Thanks a lot Yeray :D
Guilz
