WindRose SetMirrorAngles() member not found
wuhu_software
Post by wuhu_software » Thu Dec 24, 2009 4:35 pm
The code compiles fine, but when I run my program, I receive a dialog saying "member not found".
If I remove the line of code, there is no problem.
Example (C++ 6.0):
m_WindRose.Series(0).GetAsWindRose().SetMirrorAngles(TRUE);
Thank you in advance.
Re: WindRose SetMirrorAngles() member not found
Post by Yeray » Mon Dec 28, 2009 9:35 am
Hi wuhu_software,
This seems very similar to the discussed here. I've added this to the bug ticket description (TA05014604) so that both problems will be revised at the same time.
