Hello.
Have some problem with chart TeeChartNET2009VSNET2008_4.0.2009.62332.exe
1.Has blank point, when 3D chart is rotated(with rotate tool).(Chart has some series.)
2.Apear new line brom begin point to end point, when rotate 3D chart and used zoom.
Wrap chart, when rotate it
- 2.JPG (20.88 KiB) Viewed 4161 times
- 1.JPG (22.43 KiB) Viewed 4166 times
Re: Wrap chart, when rotate it
Hi petroV,
Could you please arrange and send us a simple example project we can run as-is to reproduce the problem here?
sample code
using System;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
namespace TestTeeChart
private void Form1_Shown(object sender, EventArgs e)
Random rnd = new Random();
double x = 0;
double y = 0;
double z = 0;
for(int i= 0;i< rnd.Next(10);i++)
Steema.TeeChart.Styles.Points3D points = new Steema.TeeChart.Styles.Points3D(tChart1.Chart);
for(int k = 0; k<5; k++)
points.Add(x, y, z);
x++; y++; z++;
x--;y--;z--;
- 2.JPG (31.02 KiB) Viewed 4134 times
- 1.JPG (33.92 KiB) Viewed 4138 times
Hi petroV,
Thanks for the code. I could reproduce the problem here so I've added it to the defect list to be fixed in future releases (TF02014744).
