Bar chart having massive data not displayed in IE
Beige
Post by Beige » Thu Apr 01, 2010 11:24 am
I have multiple charts in my web page. When amount of data is less each chart is displayed properly. But if amount of data is too high, charts are not displayed properly or not at all. This happens to IE only. I have test with IE6 & IE7. Charts are displayed properly in Mozilla Firefox even for large amount of data.
Please suggest any solution.
Re: Bar chart having massive data not displayed in IE
Post by Narcís » Thu Apr 01, 2010 1:24 pm
Hi Beige,
Can you please attach a simple example project we can run "as-is" to reproduce the problem here?
Beige
Post by Beige » Thu Apr 01, 2010 2:44 pm
Hi Narcís - thanks for reply.
I attached the sample application
TestChart.zip
(78.6 KiB) Downloaded 580 times
. I have excluded the Teechart.dll file from the bin folder as it is too big in size and don’t allow me to attach the sample application. I version of the dll I have is 2.0.2306.26232.
Unzip and launch default.aspx in IE.
Just put some integer value in the text box and press the 'Show Chart' button. Multiple charts will be displayed till you enter 20. Enter 25 or higher number in the box and press the button, you will have the problem reproduced.
Beige
Post by Beige » Mon Apr 05, 2010 8:45 am
Hi Narcís - Are you able to reproduce the problem. I have one more update for you. The problem is not reproducible in IE8.
Post by Narcís » Tue Apr 06, 2010 1:16 pm
Hi Beige,
Thanks for the example and feeback. I have been able to reproduce the issue in IE7 and added it (TW77014782) to the bug list to be investigated for future releases.
