3D Pie Chart boundary is very ugly on v2010
Chula
Post by Chula » Thu Apr 15, 2010 2:47 pm
I think I don't have to attach a sample. It is obvious.
I kept v8.06 on D2007 while v2010 on D2009, just load the same form with TeeChart of 3D Pie Chart with some elevation. Be warned, it may hurt your eyes :evil:
Chula
Re: 3D Pie Chart boundary is very ugly on v2010
Post by Chula » Fri Apr 16, 2010 3:13 am
Below was come from my real project.
Left-hand-side: D2007 IDE with TeeChart v8.06
Right-hand-side: D2009 IDE with TeeChart v2010
It is the same delphi form. The color difference was due to the 3D Gradient bug.
Post by Yeray » Fri Apr 16, 2010 8:03 am
Hi Chula,
That's the same discussed here. Isn't it?
Post by Narcís » Fri Apr 16, 2010 2:33 pm
Hi Chula,
Regarding pen's issue, can you please attach a simple example project we can run "as-is" to reproduce the problem here?
BTW: Have you tried using GDI+ canvas? It enhances chart rendering and it's used by default with 2010's features demo, available at TeeChart's program group. An example using new GDI+ component in the tool palette can be found at What's New?\New Components\GDI+.
Hope this helps!
Chula
Post by Chula » Wed Apr 21, 2010 3:47 am
Attached please find an example. Created with Delphi 2009 + TeeChart Pro v2010.
Please also ntoe that the Pie Chart in runtime does not fully follow the settings during design-time, like 3D elevation, it changes on its own way. Please fix it also.
Adding GDI+ did not help the boundary smoothness.
V2010 Ugly Pie.zip
(4.79 KiB) Downloaded 322 times
Post by Yeray » Thu Apr 22, 2010 9:28 am
Hi Chula,
We've tried your project and couldn't get a pie with the pen you got in the picture above. Are you using the TeeChart v2010 that is actually downloadable (eval or pro) or are you using a previous beta?
Here is what we are getting with your application:
Pie with TeeChart v2010 (GDI)
Pie with TeeChart v2010 (GDI+)
Chula wrote:Please also ntoe that the Pie Chart in runtime does not fully follow the settings during design-time, like 3D elevation, it changes on its own way. Please fix it also.
You are right. I've added it to the defect list to be fixed in future releases (TV52014827).
Chula
Post by Chula » Tue Apr 27, 2010 4:16 am
I only have the paid version and downloaded only once.
Post by Narcís » Thu May 06, 2010 7:22 am
Hi Chula,
Sorry for the delayed reply. We are unable to reproduce the aliased pie as in the v2010 image you posted. Could you please attach a simple example project we can run "as-is" to reproduce the problem here?
Post by Yeray » Fri May 14, 2010 3:24 pm
Hi Chula,
Can you reproduce the same pen effect in another machine?
