Changed behavior in legend
Uli
Post by Uli » Mon Jun 21, 2010 12:30 pm
due to the last discovered problem http://www.teechart.net/support/viewtop ... =4&t=11243 concerning wrong axis scaling I immediately checked the new release (Build 4.0.2010.27963, it was published a few minutes after that posting).
This earlier posting is related to a strange axis scaling and therefore I will not add the new problem to this thread. But there you can see how the legend appears with the old release http://www.teechart.net/support/viewtop ... =4&t=11243
When I now open the same *.ten file (it's contained in the *.zip of the above URL) in my application compiled with the newest release it looks so:
The black legend items text disappeared (the white text is due to another bug explained below)
The reason is:
In order to get sub- and superscripts I go the following way:
- creating custom rich text for legend items
- setting the "regular" legend font to color.transparent but the same size as in my "custom" rich text
- drawing the "custom" legend items in a function called from within the TChart.AfterDraw event using "regular" items properties:
        X = MyChart.Legend.Items(series).Left
        Y = MyChart.Legend.Items(series).Top
And here is the error now: Both X and Y are zero in the application compiled with the new TeeChart release.
You can easiliy check it out:
    Dim lineser As Steema.TeeChart.Styles.Line
    Dim lineser2 As Steema.TeeChart.Styles.Line
    Private Sub Form1_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
        lineser = New Steema.TeeChart.Styles.Line(TChart1.Chart)
        lineser.FillSampleValues()
        lineser2 = New Steema.TeeChart.Styles.Line(TChart1.Chart)
        lineser2.FillSampleValues()
    End Sub
    Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
        TChart1.Legend.CustomPosition = True
        TChart1.Legend.Color = Color.Transparent
        TChart1.Legend.Font.Color = Color.Transparent
        TChart1.Export.Image.Metafile.CopyToClipboard()
        Dim x As String = TChart1.Legend.Items(0).Left.ToString
        MsgBox(x)
    End Sub
    Private Sub TChart1_AfterDraw(ByVal sender As System.Object, ByVal g As Steema.TeeChart.Drawing.Graphics3D) Handles TChart1.AfterDraw
        MsgBox(x)
    End Sub
And another bug becomes visible (the code in Button1_Click is to follow this): The image above was exported as metafile to clipboard:
ActChildForm.Chart1.Export.Image.Metafile.CopyToClipboard()
and then pasted into MS paint.
You can easily see that the "regular" legends font color (which was set to transparent) is not transparent ***.
This error occurs during metafile export since a screen copy (by means of Windows 7 snipping tool) results in this image:
Here the "regular" legend font seems to be really transparent.
Please note: The file extension ".fxy" I use in tradition of the old application which shall be replaced by the new one with TeeChart. But the *.fxy files are native *.ten files with no attempts of extending serialization.
What to do?
Uli
***if you can see it not then your monitor settings may be not appropriate: You could increase the contrast in the image editor in order to see the effect.
Re: Changed behavior in legend
Post by Sandra » Tue Jun 22, 2010 11:34 am
Hello Uli,
I could reproduce it and I have added in bug report list with number [TF02014990]. We will try to fix it with next versions of TeeChart .Net.
The reason is:
I test your code with previous version of TeeChart.Net and last version and you are right, in last version X and Y values are zero. I have added it in bug report list with number [TF02014992]. We will try to fix it for next maintenances releases.
I think that is a problem of Buffer, I recommend that use next lines of Code:
        TChart1.Graphics3D.BufferStyle = Steema.TeeChart.Drawing.BufferStyle.OptimizedBuffer
Please, could you check if previous code works as you want?
I hope will helps.
Uli
Post by Uli » Tue Jun 22, 2010 11:57 am
Hi Sandra,
do you have a workaround in order to get the legend.items.top and left properties?
I added the line
to the code sample in my initial message. After pasting the image into MS Paint the white legend item text is still visible. So this code is not the solution.
Uli
Post by Christopher » Wed Jun 23, 2010 8:59 am
Uli,
Uli wrote: When I now open the same *.ten file (it's contained in the *.zip of the above URL) in my application compiled with the newest release it looks so:
Try:
tChart1.Legend.Font.Color = Color.Black;
having imported the file.
Uli wrote: And here is the error now: Both X and Y are zero in the application compiled with the new TeeChart release.
Try:
    private Line line1, line2;
      line1 = new Line(tChart1.Chart);
      line2 = new Line(tChart1.Chart);
      line1.FillSampleValues();
      line2.FillSampleValues();
      tChart1.Legend.CustomPosition = true;
      tChart1.Legend.Items.Custom = true;
      tChart1.Draw();
      MessageBox.Show(tChart1.Legend.Items[0].Left.ToString());
Uli wrote: And another bug becomes visible (the code in Button1_Click is to follow this): The image above was exported as metafile to clipboard:
Try:
tChart1.Export.Image.PNG.CopyToClipboard();
Uli wrote: What to do?
Good question! ;-)
Thank you!
http://groups.google.com
http://codenewsfast.com/
Uli
Post by Uli » Wed Jun 23, 2010 9:21 am
Hi Christopher,
Uli wrote:When I now open the same *.ten file (it's contained in the *.zip of the above URL) in my application compiled with the newest release it looks so:
Try:
That is a misunderstanding, please see my first post: The "black legend items text" is my "custom item text" (a rich text format string) which should be drawn instead of the "regular TeeChart items" in the AfterDraw events. The white text is that of the regular items for which the legend font was set to color.transparent. It's explained above in more detail. So with your proposal only the "regular items" would become visible - the opposite of my intention.
Again: What to do?
Best regards
Uli
Post by Sandra » Wed Jun 23, 2010 12:54 pm
Hello Uli,
You could use solution that Christopher suggest (tChart1.Export.PNG.CopyToClipboard()). Or if you prefer export image of Metafile I recommend that use next code that works correctly here with last version of TeeChart.Net.
        TChart1.Legend.Transparency = 100
        TChart1.Export.Image.Metafile.EMFFormat = System.Drawing.Imaging.EmfType.EmfPlusOnly
        TChart1.Export.Image.Metafile.Save("c:\\teeChart1.emf")
Using previous code I have got next image in .emf format:
teeChart1.zip
(3.29 KiB) Downloaded 1027 times
Please, could you tell us if previous code solve your problem?
I hope will helps.
Uli
Post by Uli » Wed Jun 23, 2010 3:09 pm
Hi Sandra,
sorry, I overlooked the code sample suggested by Christopher:
With
the items top and left properties are now OK, my custom items were drawn. Thanks!
With respect to the other issue ("regular item text" visible after copying to clipboard): I tried it out now. Unfortunately, Christophers suggestion
        TChart1.Export.Image.PNG.CopyToClipboard()
leads only to an empty chart (no data series) in Word or Paint.
With your proposal
I still get the white "regular items" text by copy to/paste from clipboard.
The alternative to import the chart into other applications by first saving the file is highly uncomfortable and fuzzy. Are there further possibilities?
Best regards
Uli
Post by Sandra » Fri Jun 25, 2010 8:42 am
Hello Uli,
Ok, I have added it in Bug list with number [TF02015005] and we try to fix it for next maintenance releases of TeeChart.Net.
Could you please explain us exactly what are you doing? Because we can try to find other solution for help you.
Uli
Post by Uli » Fri Jun 25, 2010 9:27 am
Hi Sandra,
I don't know what you need as "exact" explanation, the details are all in the previous postings. I will try to summarize again:
I need to draw rich text in the legend items. In order to get sub- and superscripts I go the following way:
- creating custom rich text for legend items. This is a RichTextBox.RTF string.
- setting the "regular" legend font to color.transparent but the same size as in my "custom" rich text. (must be invisible)
- drawing the "custom" legend items (the RichTextBox.RTF) in a function called from within the TChart.AfterDraw event using "regular" items
properties
- the "regular" items text properties hold the unformated text of the rich text (in order to use the "regular" legend with, height, ...,
properties)
More details you may find in the previous messages.
In the initial message I described two issues:
(1)
With the last release the legend items top and left properties were zero in the TChart.AfterDraw event ([TF02014990]). This problem could be overcome by the code suggested by Christopher.
(2)
I need to export the chart as image into Word and other applications. The export as metafile results in images where the "regular" items text becomes visible (though the legend font was set to color.transparent) as white "ghost" text below the "custom" rich text. You and Christopher suggested some code to overcome this but it does not work. The possibility to save the chart as a file and then to import this file into the other applications is not an acceptable alternative.
Uli
Post by Sandra » Fri Jun 25, 2010 10:50 am
Hello Uli,
Sorry if I explained too well. I wanted to refer concretely to the export of image that is your last explanation.
I try again code that suggest Christopher and here seems that works fine with last version of TeeChart.Net and using next code:
  private Steema.TeeChart.Styles.Line lineser, lineser2;
            lineser = new Steema.TeeChart.Styles.Line(tChart1.Chart);
            lineser.FillSampleValues();
            lineser2 = new Steema.TeeChart.Styles.Line(tChart1.Chart);
            lineser2.FillSampleValues();
            tChart1.Legend.Color = Color.Transparent;
            tChart1.Legend.Font.Color = Color.Transparent;
            tChart1.Graphics3D.BufferStyle = Steema.TeeChart.Drawing.BufferStyle.OptimizedBuffer;
I get next image .png with chart full:
Do you get a same as snippet image above?
Uli
Post by Uli » Fri Jun 25, 2010 12:05 pm
Hi Sandra,
I tried the code of Christopher with a minimal sample application again. Now it works. I just realized that the first attempt I carried out with my current code under work and I forgot to comment out a following line which copied another empty chart... Sorry! Obviously I was a little bit confused since I tried some other things, too.
I assume this as a workaround with which I can live up to the next maintenance release. But you are still asked to make possible a correct metafile copy via clipboard since the png copy looks not so good when changing the size.
Best regards
Uli
Uli
Post by Uli » Fri Jun 25, 2010 1:16 pm
Supplement to last posting
Hi Sandra,
in his message Christopher suggested
to be able to get the legend items top and left values and
to solve the problem with the "ghost" text. So I checked both for the individual problems to solve (and did it wrong with respect to the png export).
After submitting the last message I went back to my actual code to implement the png clipboard export. And asked me the question whether the
may eventually have an influence on the metafile file export, too. And it has: The metafile export seems now to work correctly!
Have a nice weekend
Uli
Uli
Post by Uli » Thu Jul 15, 2010 9:36 am
Hi Sandra,
after my euphoria in the last message that Christopers workaround solves the problem with metafile (it was my first impression) some deeper testing was done. In summary, this has shown that with bug number [TF02014990] sufficient work with the legend is not more possible. I again wasted a lot of hours to come to this conclusion.
So I have to ask you: Can you provide an assembly where this bug is fixed? Of course, I would be glad if the other bugs which make my work with TeeChart so extremly frustrating would be fixed in this assembly, too.
Best regards
Uli
Post by Narcís » Thu Jul 22, 2010 11:10 am
Hi Uli,
Sorry for the delayed reply. Please see Marc's answers here.
