QR5 and Delphi 2010
WilliEbert
QR5 and Delphi 2010
Post by WilliEbert » Tue Sep 14, 2010 7:57 pm
there are no packages for QR5, Delphi2010 and the new TeeChart 2010 like with TeeChart 8 (Tee8QR5D14).
Can you help me?
Your sincerely
Willi Ebert
Re: QR5 and Delphi 2010
Post by Yeray » Wed Sep 15, 2010 3:10 pm
Hi Willi,
I've just answered the same question here
WilliEbert
Post by WilliEbert » Wed Sep 15, 2010 3:22 pm
Hello Yeray,
there are packages for QR5 and Delphi5 to Delphi 2007 and Delphi 2011 (DclTee9QR5D5.dpk..DclTee9QR5D15.dpk). I don't understand why the version for Delphi 2010 is not includes in the TeeChart 2010 Pro Version?
Your sincerely
Willi Ebert
Post by Yeray » Fri Sep 17, 2010 1:28 pm
Hi Willi Ebert,
We are investigating why these packages aren't shipped with the last TeeChart version.
In the meanwhile, following the instructions in the QuickReport article you should be able to prepare them by yourself.
WilliEbert
Post by WilliEbert » Mon Sep 20, 2010 3:09 pm
your sample didn't help me at all. If i changed the files like in your sample i get allays this error:
[DCC Fataler Fehler] TeeQRTeeReg.pas(17): F2084 Interner Fehler: U2186
Line 17 of TeeQRTeeReg.pas is:
Uses Classes, DBChart, TeeConst, QRTee, SysUtils,
Meanwhile there is much trouble about this error. Please help me
Your sincerely
Willi Ebert
Post by Yeray » Mon Sep 20, 2010 3:39 pm
Hi Willi Ebert,
The following sources seem to work fine for me here.
Follow the instructions in the article mentioned above to compile them.
Tee9QR5D14.zip
(8.77 KiB) Downloaded 621 times
WilliEbert
Post by WilliEbert » Wed Sep 22, 2010 10:22 am
Hello Yeray,
with your source files i get still internal errors, but meanwhile i found a workaround. If i compile the package without compiler optimization i can install the TQRChart component. This is ok for me till i found a better solution.
Your sincerely
Willi Ebert
