Is it possible to plot several charts on one tchart control without overprinting of the axes?
I have plotted 12 Ternary charts, each containing a seperate set of data. However, the axes and labels overprint each other, resulting in blurry text.
See jpeg...
Plotting Several Charts
- ternarysteema.jpg (19.68 KiB) Viewed 6003 times
Re: Plotting Several Charts
Hello lilo,
I've added to the ticket number [TF02015203]. So the enhancement would be implemented in next versions of TeeChart.Net.
Well, seems it is a known issue (TV52015067) recently discussed in the VCL forums as you'll see hereIs it possible to plot several charts on one tchart control without overprinting of the axes?
We also like to have a font property for the vertex labels and a fix for the right vertex 0 label - does not update font size properly when font size is changed for labels.
Hello lilo,
I have added your suggestion as a feature request with number [TF02015224] to be considered for inclusion in future versions of TeeChart.NetWe also like to have a font property for the vertex labels
You are right. I have added your request in bug list with number [TF02015226]. We will try to fix it for next maintenance releases of TeeChart.Net.a fix for the right vertex 0 label - does not update font size properly when font size is changed for labels.
