looking through the forums, ive found a reference back in 2007 asking for zooming in the webchart to work for custom axes. it was listed as a soon to be added feature.
at the moment i zoom in on my chart (datetime x axis), and i have 2 custom horizontal axes with different lengths below the default bottom axis
there is no event to capture for zooming in asp.net, so i figured when im checking for the zoomed arraylist, i would adjust each custom axis min and max.
ive come a little stuck with the fact my custom axes are all "different" ranges of values. for example, the default is datetime, the 1st custom is a range of 0-x days, and the 2nd custom is a range of degrees...
how can i get the max and min of the zoom rectangle for these custom axes...
or is there a teechart implementation i can use that ive been unable to find in the help documentation.
version 3.5 of teechart.
webchart zooming custom axis
Re: webchart zooming custom axis
Hello simon,
It is a feature request known for us and is it in wish-list with number [TW77012342] and we have increased its priority. Moreover, I have made a simple example for that I think you can use in your application:
Please, could you check if previous code works as you want?
I hope will helps.
Steema.TeeChart.Styles.FastLine series1, series2, series3;
Steema.TeeChart.Axis bottomAxis1, bottomAxis2, bottomAxis3;
Steema.TeeChart.Tools.ZoomTool tool1;
System.IO.MemoryStream tmpChart;
bool zoomed;
protected void Page_Load(object sender, System.EventArgs e)
Steema.TeeChart.Chart ch1 = WebChart1.Chart;
tmpChart=new System.IO.MemoryStream();
if (Session["ch1"] == null)
ch1.AutoRepaint = false;
ch1.Aspect.View3D = false;
tool1 = new Steema.TeeChart.Tools.ZoomTool(WebChart1.Chart);
tool1.ZoomPenColor = System.Drawing.Color.OliveDrab;
ch1.Panel.Gradient.Visible = false;
ch1.Walls.Visible = false;
series1 = new FastLine(ch1);
series2 = new FastLine(ch1);
series3 = new FastLine(ch1);
series1.FillSampleValues();
series2.FillSampleValues();
series3.FillSampleValues();
Steema.TeeChart.Axis bottomAxis = ch1.Axes.Bottom;
bottomAxis1 = bottomAxis.Clone() as Steema.TeeChart.Axis;
bottomAxis1.StartPosition = 0;
bottomAxis1.EndPosition = 25;
bottomAxis2 = bottomAxis.Clone() as Steema.TeeChart.Axis;
bottomAxis2.StartPosition = 30;
bottomAxis2.EndPosition = 55;
bottomAxis3 = bottomAxis.Clone() as Steema.TeeChart.Axis;
bottomAxis3.StartPosition = 60;
bottomAxis3.EndPosition = 85;
//series1.CustomHorizAxis = bottomAxis1;
ch1.Axes.Bottom.EndPosition = 25;
series2.CustomHorizAxis = bottomAxis2;
series3.CustomHorizAxis = bottomAxis3;
ch1.Panel.MarginBottom = 10;
ch1.Export.Template.IncludeData = true;
ch1.Export.Template.Save(tmpChart);
//save template to a Session variable
Session.Add("ch1", tmpChart);
series1.BeforeDrawValues = new Steema.TeeChart.PaintChartEventHandler(series1_BeforeDrawValues);
series1.AfterDrawValues = new Steema.TeeChart.PaintChartEventHandler(series1_AfterDrawValues);
series2.BeforeDrawValues = new Steema.TeeChart.PaintChartEventHandler(series1_BeforeDrawValues);
series2.AfterDrawValues = new Steema.TeeChart.PaintChartEventHandler(series1_AfterDrawValues);
series3.BeforeDrawValues = new Steema.TeeChart.PaintChartEventHandler(series1_BeforeDrawValues);
series3.AfterDrawValues = new Steema.TeeChart.PaintChartEventHandler(series1_AfterDrawValues);
//retrieve the session stored Chart
tmpChart = (System.IO.MemoryStream)Session["ch1"];
//set the Stream position to 0 as the last read/write
//will have moved the position to the end of the stream
tmpChart.Position=0;
//import saved Chart
WebChart1.Chart.Import.Template.Load(tmpChart);
CheckZoom(WebChart1);
WebChart1.Chart[0].BeforeDrawValues = new Steema.TeeChart.PaintChartEventHandler(series1_BeforeDrawValues);
WebChart1.Chart[0].AfterDrawValues = new Steema.TeeChart.PaintChartEventHandler(series1_AfterDrawValues);
WebChart1.Chart[1].BeforeDrawValues = new Steema.TeeChart.PaintChartEventHandler(series1_BeforeDrawValues);
WebChart1.Chart[1].AfterDrawValues = new Steema.TeeChart.PaintChartEventHandler(series1_AfterDrawValues);
WebChart1.Chart[2].BeforeDrawValues = new Steema.TeeChart.PaintChartEventHandler(series1_BeforeDrawValues);
WebChart1.Chart[2].AfterDrawValues = new Steema.TeeChart.PaintChartEventHandler(series1_AfterDrawValues);
WebChart1.Chart.Invalidate();
void series1_AfterDrawValues(object sender, Steema.TeeChart.Drawing.Graphics3D g)
if (zoomed)
g.UnClip();
void series1_BeforeDrawValues(object sender, Steema.TeeChart.Drawing.Graphics3D g)
if (zoomed)
Series s = sender as Series;
double left = s.GetHorizAxis.IStartPos;
double right = s.GetHorizAxis.IEndPos;
double top = s.GetVertAxis.IStartPos;
double bottom = s.GetVertAxis.IEndPos;
g.ClipRectangle((int)left, (int)top, (int)right, (int)bottom);
private void CheckZoom(Steema.TeeChart.Web.WebChart WebChart1)
System.Collections.ArrayList zoomedState = (System.Collections.ArrayList)Session[WebChart1.ID "Zoomed"];
zoomedState = ((Steema.TeeChart.Tools.ZoomTool)WebChart1.Chart.Tools[0]).SetCurrentZoom(Request,
zoomedState);
if (zoomedState == null)
Session.Remove(WebChart1.ID "Zoomed");
zoomed = false;
for (int i = 0; i < WebChart1.Chart.Series.Count; i )
if (ch1[i].GetVertAxis.IsCustom())
ch1[i].CustomHorizAxis.Automatic = true;
Session.Add(WebChart1.ID "Zoomed", zoomedState);
zoomed = true;
for (int i = 0; i < ch1.Series.Count; i )
Steema.TeeChart.Axis axis = ch1[i].GetHorizAxis;
if (axis.IsCustom())
axis.SetMinMax(ch1.Axes.Bottom.Minimum, ch1.Axes.Bottom.Maximum);
I hope will helps.
not quite what i was looking for.
ive come up with a poor solution... but should suffice until the feature is added (though the feature wont make back into 3.5, so id have to upgrade). i should note that i still doesnt work exactly as needed, but im working on it.
attached is a picture of the scenario i was attempting to describe.
notice that the GDD axis doesnt match up.
if you have a further solution, let me know...
- teechartzoom.png (72.83 KiB) Viewed 6786 times
