Logarithmic scaling issue
Hi All,
Attached is a project of a price chart with an option to view it in logarithmic mode. When the chart is viewed in logarithmic mode the scaling disappears and the chart doesn't seem to be modified.
Is this a known bug or have I not setup the chart correctly to display in logarithmic mode?
- LogChart.zip
- (54.99 KiB) Downloaded 418 times
Cheers Phil.
Cheers Phil.
Re: Logarithmic scaling issue
Hello Phil,
I have tested your project and here I have obtained results below:
Image1: Not Log Left Axis Image2: Log Left Axis I think that behaviour of Chart is correct using last version of TeeChart.Net 2010. If you are using TeeChart.Net 2010 and you don't believe results are correct, please explain us why, so we can help you. On the other hand, if you don't use last version TeeChart.Net 2010 please, tell us which version of TeeChart you are using now.
Hi Sandra,
Your screen shots are different to what my chart displays, especially the scaling on the non log screen shot. I have posted screen shots of what my chart looks like in non log and log. The version of TeeChart used for the sample applicaiton is 4.1.2010.11301.
- Log
- Log.jpg (146.26 KiB) Viewed 8996 times
- Non Log
- No Log.jpg (146.26 KiB) Viewed 8997 times
Cheers Phil.
Cheers Phil.
Hi Phil,
I'm taking up on this issue because Sandra is out of the office this week.
I get the same behavior as Sandra using both our current TeeChart for .NET 2010 sources and latest maintenance release available at the client area, which is the version you say you are using. However, checking your zip package, I see that TeeChart.dll in \bin\Debug folder it's build number 4.0.0.30714, which doesn't coincide with any of the binary releases we have published. I have checked that you are a source code customer so I assume this is an assembly you built from the sources. Can you please confirm that? Can you please check if the problem persists with latest binary release available at the client area? What we get is what you expect?
Hi Narcís,
I've added a reference to the latest tChart.dll (4.1.2010.11301) and re-uploaded my project. With this reference I still get the same issue as originally reported (scale disappears and chart shape doesn't change when going into log mode).
Do you get the same screen shot as what I posted with log mode off? If not, could you post a sample project using the latest dll release to see if I get the same behaviour as you.
- LogChart.zip
- (15.45 KiB) Downloaded 414 times
Cheers Phil.
Cheers Phil.
Hi Phil,
Thanks for the sample project. I'll do the test you requested but I have a problem with the files you sent. You didn't include the "Properties" folder and the project can not be compiled. Could you please resend the project or just this folder? "bin" and "obj" folders can be removed but not "Properties" folder.
Sorry about that Narcís, attached is the project again.
- LogChart.zip
- (16.91 KiB) Downloaded 368 times
Cheers Phil.
Cheers Phil.
Hi Phil,
Thanks for the files. I'm still getting the same as Sandra using it. I just added the reference to TeeChart.dll build 4.1.2010.11303, which is the latest release for VS2010. Then I changed project's target framework to 4.0 as build 4.1.2010.11303 is for that framework, compiled the application and got the screen-shots below. Actually I also added some code to export the images. Find also attached the project with the changes I told you. Following those steps do you get the same as we do? Please notice that Visual Studio may not be using the TeeChart assembly you think, I recommend you to remove TeeChart's AssemblyFolders entry as I described here before starting VS2010.
- LogChart.zip
- (6.68 KiB) Downloaded 419 times
Hi Narcís,
I've downloaded your project but still don't get the same screen shots as you. I'm using 4.1.2010.11301 of the DLL instead of 4.1.2010.11303. Would this make a difference?
Also, I can't see how you get your screen (with Log off) as you seem to have 2 different scales on the left hand side. You have 0 to 800 and then another scale from 1.000 up to 4.600. The min and max values being plotted however are 35.58 and 46.59 so I don't know if you are using another data set to populate the chart?
Cheers Phil.
Cheers Phil.
Hi Phil,
Sorry, my bad. Now I have found which was the difference between your project and hours. I had to set my regional settings to English (US) to get the same as you get. I guess my settings (Catalan) were interpreting decimal and thousand separators in a different way. I think the problem is that no logarithmic labels as your data goes from 35.5 to 46.5 approximately. This means they don't fall into a range that a logarithmic label (1, 10, 100, 1000, etc.) label is displayed. I modified your code a little bit to modify left axis minimum and maximum values when it's logarithmic so that labels are displayed:
Another alternative would be using custom labels. You can find an example at All Features\Welcome !\Axes\Labels\Custom labels in the features demo, available at TeeChart's program group.
if (SemiLogActive == false)
tChart1.Axes.Right.Logarithmic = true;
tChart1.Axes.Left.LogarithmicBase = 10;
tChart1.Axes.Right.LogarithmicBase = 10;
tChart1.Axes.Left.SetMinMax(10, 100);
tChart1.Refresh();
SemiLogActive = true;
button1.Text = "Turn Off Semi Log";
GetScreenShot("Log.png");
tChart1.Axes.Left.Logarithmic = false;
tChart1.Axes.Right.Logarithmic = false;
tChart1.Axes.Left.Automatic = true;
tChart1.Refresh();
button1.Text = "Turn On Semi Log";
SemiLogActive = false;
GetScreenShot("NoLog.png");
