MHotz
Post
by MHotz » Mon Oct 24, 2011 3:40 pm
is it possible to create a chart that looks similar to that one I attached as an image? I mean the cylinder only. The tube surrounding the cylinder could be a backimage. I tried the cylinder series type but that doesn't look so smooth as in the image. And we don't want to use neither Open GL nor GDI+.
Thanks for your support!
Regards Markus
Post
by Yeray » Tue Oct 25, 2011 7:53 am
Hello Markus,
I'm afraid the smoothed curves is one of the GDI limitations.
Here you have the results I get with GDI, GDI+ and GDI&AntiAliasTool.
Chart1.Chart3DPercent:=100;
FillSampleValues();
BarStyle:=bsCilinder;
MultiBar:=mbSelfStack;
Marks.Visible:=false;
ColorEachPoint:=true;
Dark3D:=false;
- CylinderGDI.png (8.33 KiB) Viewed 14441 times
- CylinderGDIPlus.png (18.07 KiB) Viewed 14428 times
- CylinderAntiAliasTool.png (12.76 KiB) Viewed 14434 times
MHotz
Post
by MHotz » Thu Oct 27, 2011 11:30 am
Thanks for your Reply!
But how was this chart
created? This is an example from the steema gallery. Theses are also cylinders but they look very much better than the regular cylinder bar chart. Using the regular cylinder bar chart one have very few options to change the look of the cylinders. E.g. using a gradient fill.
Thanks again for your help!
Greetings Markus
Post
by Yeray » Thu Oct 27, 2011 2:34 pm
Hello
This example from the gallery was made with TeeChart .NET and some of Micrsoft .NET Framework drawing techniques are not available in the VCL framework.
However, with GDI+ and the following code I get a quite similar result:
- Tower.png (197.63 KiB) Viewed 14423 times
uses TeeSurfa, TeeGDIPlus, TeeTools;
with TTeeGDIPlus.Create(self) do
TeePanel:=Chart1;
Active:=true;
Chart1.Title.Visible:=false;
Chart1.Legend.Visible:=false;
Chart1.Aspect.Orthogonal:=false;
Chart1.Aspect.Zoom:=70;
Chart1.Aspect.Rotation:=325;
Chart1.Aspect.Elevation:=340;
Chart1.Walls.Left.Size:=10;
Chart1.Walls.Bottom.Size:=10;
with Chart1.Tools.Add(TGridBandTool) as TGridBandTool do
Axis:=Chart1.Axes.Left;
Band1.Color:=clGrayText;
Band1.Transparency:=50;
Band2.Transparency:=50;
with Chart1.AddSeries(TTowerSeries) as TTowerSeries do
FillSampleValues();
Origin:=YValues.MinValue+(YValues.MaxValue-YValues.MinValue)/2;
UseOrigin:=true;
TowerStyle:=tsCylinder;
Dark3D:=false;
Transparency:=30;
UseColorRange:=false;
UsePalette:=true;
MHotz
Post
by MHotz » Fri Oct 28, 2011 11:36 am
thank you very much for your in depth answer! No I see things clearer
I decided to go another way and for that I need one more information. How can I get the exact position of a single series value point? I mean the X and Y coordinates and the Height and Width of a column that was drawn by the chart.
Post
by Yeray » Fri Oct 28, 2011 3:04 pm
Check the series' CalcXPos and CalcYPos functions.
MHotz
Post
by MHotz » Fri Oct 28, 2011 3:33 pm
That's ok. And the Height and Width of a value point? Or the Right and Bottom Coordinates? Are theses values also available? I want to know the BoundsRect of a value point (e.g. Bar)
Greetings Markus
MHotz
Post
by MHotz » Sat Oct 29, 2011 7:28 pm
I moved a bit further. I found out how to get the BoundRect of a TBarSeries. So I am able to cover a bar with images so that I receive the result I want. But now I have another problem. I want to export my chart to a png file. The chart contains some png images with alpha channel. Exporting the chart to png in
Delphi 2010 all works fine as you can see in that image
But If I do the same with the same code in
Delphi 2007 the result looks like this:
I am using the following code to do the export
tmp := TPNGExportFormat.Create;
tmp.Panel := Chart1;
tmp.SaveToFile(ChartImageFile);
tmp.Free;
Any idea? What's differnt in D 2007?
Post
by Narcís » Mon Oct 31, 2011 4:08 pm
Hi Markus,
Are you using exactly the same version in both Delphi? If that's the case I would expect the behavior to be identical. If the problem persists can you please attach a simple example project we can run "as-is" to reproduce the problem here?
