Common Zero for Left Axis & Bottom Axis
I'm using Steema Silverlight. My Left Y Axis Starts from Zero and Bottom Axis also starts from Zero. So I need a common Zero instead of 2 Zeros. In Windows .NET version it was working. Is there any way to achieve the same in Silverlight version.
- CommonZero.PNG (18.25 KiB) Viewed 8354 times
Re: Common Zero for Left Axis & Bottom Axis
Hello Neelam,
I have try to achieve a common 0 using the same code with Winforms and Silverlight and I have gotten the same results in both projects and these are negative. Can you tell us, which values are you using to achieve a common 0 in Winforms? On the other hand, you can solve your problem using GetAxisLabel Event and remove the 0 you don't want as do in next code:
I hope will helps.
public MainPage()
InitializeChart();
Steema.TeeChart.Silverlight.Styles.Line Series1, Series2;
Series1 = new Steema.TeeChart.Silverlight.Styles.Line(tChart1.Chart);
Series2 = new Steema.TeeChart.Silverlight.Styles.Line(tChart1.Chart);
Series1.Add(0, 35);
Series1.Add(1, 134);
Series1.Add(2, 245);
Series1.Add(2, 555);
Series2.Add(0,0);
Series2.Add(1, 50);
Series2.Add(3, 150);
Series2.Add(2, 300);
tChart1.GetAxisLabel = new Steema.TeeChart.Silverlight.GetAxisLabelEventHandler(tChart1_GetAxisLabel);
void tChart1_GetAxisLabel(object sender, Steema.TeeChart.Silverlight.GetAxisLabelEventArgs e)
if (sender == tChart1.Axes.Left)
if (e.LabelText == "0")
e.LabelText = " ";
