TeeMaker /TChart3D is not installed in XE2
jls
Post by jls » Mon Apr 16, 2012 9:58 am
I use the recompile tool and check out for install TChart3D , but it is not.
any reason?
Re: TeeMaker /TChart3D is not installed in XE2
Post by Yeray » Mon Apr 16, 2012 10:32 am
What TeeChart version are you using. Here with TeeChart v2012.05 I see the TeeMaker component installed in XE2:
And I see the TChart3D component in the palette:
jls
Post by jls » Mon Apr 16, 2012 12:20 pm
if i install ttree tmaker is also installed
I don't want to install ttree
Post by Yeray » Mon Apr 16, 2012 1:23 pm
Selecting "Tee 3D" (and not "TeeTree") in TeeRecompile:
Installs TeeMaker for me here and not "TeeTree 2 components" as in the post above:
Doesn't it do the same for you?
jls
Post by jls » Tue Apr 17, 2012 7:42 am
now it is OK, don't know why it was gone the first time,
but I'm not able to use it
the demo
http://www.teechart.net/support/viewtop ... 107#p52331
dosn't work
1) access violation designtime
2)stack overflow runtime (it compiles)
Post by Yeray » Tue Apr 17, 2012 9:44 am
jls wrote:the demo
viewtopic.php?f=3&t=11921&p=51107#p52331
dosn't work
If that's the problem you reported here, I think it's more logical to continue the conversation there.
