URGENT::Latest 2012 build for CG2010 causes EEFACE
401kPensionGuru
Post by 401kPensionGuru » Tue Apr 24, 2012 11:40 am
I installed the Mar 28 dnld and evrytime I run the exe I get an EEFACE -- this is an urgent matter as we are dead in water--we are using TEEChart in a very simple pie drawing in an Intraweb app...we previously had 2011 installed and it worked fine...also the pie chart does not fill properly on the left side -- it looks like two disks -- see attached pic
Re: URGENT::Latest 2012 build for CG2010 causes EEFACE
Post by Yeray » Wed Apr 25, 2012 10:35 am
401kPensionGuru wrote:I installed the Mar 28 dnld and evrytime I run the exe I get an EEFACE -- this is an urgent matter as we are dead in water--we are using TEEChart in a very simple pie drawing in an Intraweb app...we previously had 2011 installed and it worked fine...
I'm not sure to understand this. Could you please tell us the exact error message you are getting and how can we reproduce it? A simple example project we can run as-is would be the easier way for us to reproduce the problem here.
401kPensionGuru wrote:also the pie chart does not fill properly on the left side -- it looks like two disks -- see attached pic
Try with:
Series1.RotationAngle:=359;
