TeeChart2012 and TDraw3D bug for CB6
anauta2013
Post by anauta2013 » Mon Nov 05, 2012 11:37 am
I found new issue that exists in the Chart under CB6
The constuction like:
TCanvas3D *c = Draw3D1->Canvas;
c->Pen->Width = 3;
will produce Access Violation.
I had to return to TeeChart2011 to avoid this bug.
Best regards
Vladimir
vlezhu
Re: TeeChart2012 and TDraw3D bug for CB6
Post by vlezhu » Tue Nov 06, 2012 9:40 am
Hi, Yeray.
And what do you think about this bug?
Post by Yeray » Tue Nov 06, 2012 10:29 am
I've created a new simple project in BCB6 with just a Chart on the form, a TLineSeries created and populated at design time, and the code above (Chart1 instead of Draw3D1, since the chart is named Chart1 by default) at FormCreate, and I see no error at all.
Could you please arrange a simple example project we can run as-is to reproduce he problem here?
vlezhu
Post by vlezhu » Tue Nov 06, 2012 11:51 am
Sorry for poor information in the first post, I thought that it is clear.
This is example without chart, only TDraw3D component was used.
Will put TDraw3D to form and then place
c->Pen->Width = 3;
to the constructor of the form1.
After start of application you will see this error in CB6.
Post by Yeray » Tue Nov 06, 2012 12:57 pm
vlezhu wrote:Sorry for poor information in the first post, I thought that it is clear.
Sorry, my bad.
I've tried it with just a TDraw3D added on the form at design time and the code you mention in the FormCreate, and the application compiles and runs without problems for me here with TeeChart v2012.06 and C++Builder 6, in a Win7 64bit machine.
Are you reproducing this with v2012.06?
anauta2013
Post by anauta2013 » Tue Nov 06, 2012 2:22 pm
Yes, I can reproduce it on TeeChart2012 V.6
By the way, I work on Win7-32, may be this is reason?
I upload test project Test.zip
Test.zip
(3.32 KiB) Downloaded 893 times
Best regards
Vladimir
Post by Yeray » Wed Nov 07, 2012 11:00 am
I can open your project without any error. I found it gave me an error when trying to find Tee9C6.lib. I've closed the project and edited the .bpr manually to remove the all the references to Tee9C6. I've reopened the project and it builds and runs fine for me here.
It makes me think it has to be something in the paths on your IDE.
anauta2013
Post by anauta2013 » Wed Nov 07, 2012 3:57 pm
I could not find the reason for this behaviour, but after total reinstall of CB6 the bug dissappeared, thank you for the tip.
Best regards
Vladimir
