Delphi XE3 Installation fails
westy
Post by westy » Thu Nov 08, 2012 5:57 am
Hi Steema,
I have downloaded and tried running the TeeChart Pro for Delphi XE 3 installer on Windows 7 Pro 64bit. It gets to 100% but then pops up a message saying I need to manually re-install it.
I have seen a few messages about other users having problems with the Standard Version but I am trying to install the Pro version.
Any ideas of what the problem might be ?
I have an attached screenshot of the two messages I get at the end of the install.
Steve
Screenshot of post installation error for TeeChart Pro for Delphi XE3.
Re: Delphi XE3 Installation fails
Post by Yeray » Thu Nov 08, 2012 9:35 am
This is a problem identified for the PreRelease for XE3:
http://www.teechart.net/support/viewtop ... =3&t=13648
However, it should have been fixed with the release published yesterday.
Is this the version you are using?
westy
Post by westy » Thu Nov 08, 2012 12:04 pm
Actually the one I downloaded said it was published/released on 26th October. I checked again this afternoon and it was still showing the same release date in my client logon area ?
Is there somewhere else I should be downloading it from ?
This was the Pre release version but I can see there is a full version released November 6th. I will try downloading that one instead.
Steve
Post by Narcís » Thu Nov 08, 2012 2:40 pm
Hi Steve,
No, it should be that. Try refreshing the page or clearing your browser cache just in case it's not updating.
Yes, that's the final version, build number 2012.07.121105.
westy
Post by westy » Fri Nov 09, 2012 2:27 am
Hi Narcís ,
All good. The final release worked perfectly.
Steve
Post by Narcís » Fri Nov 09, 2012 7:59 am
Hi Steve,
Thanks for your feedback!
