Self-stacked bar graph with side labels?
PhilOutram
Post by PhilOutram » Tue Jan 29, 2013 9:45 am
Is it possible to create a self-stacked (single) bar graph with labels off to the side, rather than above each bar. When they're all stacked on top of each other, it makes much more sense to have the label to the side.
I'm trying to generate this graphic, which would ideally have each bar having it's own gradient colour, and a complex label on each side.
If any of the above are possible, please explain how to do it (I'm coding in VB.net). I've tried using the Chart Editor, but couldn't do the above points.
Many thanks,
Phil.
Re: Self-stacked bar graph with side labels?
Post by Sandra » Wed Jan 30, 2013 11:13 am
Hello Phil,
I think you can get as you want working with CustomLabels of Axes as I do in next simple code:
   double TotalSum;
          tChart1.Walls.Back.Visible = false;
          tChart1.Axes.Left.Grid.Visible = false;
         Steema.TeeChart.Styles.Bar Series1 = new Steema.TeeChart.Styles.Bar(tChart1.Chart);
         TotalSum = 0;
          for (int i = 0; i < 5; i++)
              Series1.Add(i, i * 100 + 5);
              TotalSum = TotalSum + Series1.YValues[i];
          //InitializeSeries.
          Series1.MultiBar = MultiBars.SelfStack;
          Series1.BarStyle = BarStyles.RectGradient;
          Series1.VertAxis = VerticalAxis.Both;
          Series1.BarWidthPercent = 100;
          Series1.Marks.Visible = false;
          Series1.SideMargins = false;
          //Set CustomLabels:
          SetCustomLabels();
      private void SetCustomLabels()
          double NewPosition = 0;
          Steema.TeeChart.Styles.Bar bar1 = (tChart1[0] as Steema.TeeChart.Styles.Bar);
          for (int i = 0; i < bar1.Count; i++)
              NewPosition = NewPosition + bar1.YValues[i];
              tChart1.Axes.Left.Labels.Items.Add(NewPosition, (Math.Round(bar1.YValues[i] * 100 / TotalSum, 2)).ToString() + "%");
          NewPosition = 0;
              NewPosition = NewPosition + tChart1[0].YValues[i];
              tChart1.Axes.Right.Labels.Items.Add(NewPosition, (bar1.XValues[i] * 100 / 10).ToString() + "%");
I hope will helps.
PhilOutram
Post by PhilOutram » Wed Jan 30, 2013 12:47 pm
Great, thanks. I'll try it at the weekend and let you know.
Phil
PhilOutram
Post by PhilOutram » Sun Feb 10, 2013 10:41 pm
Hi Sandra,
The code you sent is working pretty well. The only problem I'm having is that my single set of stacked bars are pinned to the left of the chart space and only one or so pixels wide. Can you please tell me how to get the bars to be the full width of the chart area? i.e from the left axis to the right axis with no margin?
Many thanks.
Phil.
Post by Sandra » Mon Feb 11, 2013 2:59 pm
Hello Phil,
I can not reproduce your problem using next code in last version 4.1.2012.01312:
       double TotalSum;
            TotalSum = 0;
            //InitializeSeries.
            //Set CustomLabels:
            SetCustomLabels();
            NewPosition = 0;
The result image I have gotten is next: .
Could you tell us which version of TeeChartFor.Net are you using? If you use the last version and the problem still appears for you, please send us a simple code because, we can reproduce issue here and try to find a solution for you.
PhilOutram
Post by PhilOutram » Mon Feb 11, 2013 3:18 pm
Hi Sandra,
Thanks for your quick response. The details of the TeeChart dll I'm using are...
TeeChart Dll Details.gif (26.77 KiB) Viewed 10383 times
I'll try and trim everything back to see if I can reproduce what you've got.
Lastly, is it possible to set the colour of the bars individually?
Many thanks,
Phil.
Post by Sandra » Tue Feb 12, 2013 10:16 am
Hello Phil
Thanks for information. Basically, your problem is that BarWidht property doesn't work in correct way in version 2 and it breaks your application. If you want achieve the same results than latest version TeeChartFor.Net 2012 I recommend use CustomBarWidth property as I do in next code:
 //Version 2.
      double TotalSum;
            TotalSum = 0;
            //InitializeSeries.
            Series1.CustomBarWidth = tChart1.Width;
            SetCustomLabels();
            NewPosition = 0;
        private void button3_Click(object sender, EventArgs e)
            tChart1.ShowEditor();
Yes, is possible. You can assign a color for each bar point. I have added a list of colors in my previous code that allow you assign one color for each bar point:
 double TotalSum;
        List<Color> colorList;
             colorList = new List<Color>(new Color[] { Color.Red, Color.Green, Color.Blue, Color.HotPink, Color.Black});
            TotalSum = 0;
                Series1.Add(i, i * 100 + 5,colorList[i]);
            //InitializeSeries.
            SetCustomLabels();
            NewPosition = 0;
I hope will helps.
PhilOutram
Post by PhilOutram » Mon Feb 18, 2013 12:52 am
Hi Sandra,
All the things that you've suggested have worked. Job done!
Very many thanks,
Phil.
