Cursor tool in 3d
Richard
Cursor tool in 3d
Post by Richard » Fri May 10, 2013 10:16 am
I am having problems getting the cursor tool to work in 3d. I have a chartgrid showing some data, and on mouse down I want the cursor tool to highlight the point
ie
procedure TForm1.ChartGridMouseDown(Sender: TObject; Button: TMouseButton;
Shift: TShiftState; X, Y: Integer);
ChartTool1.Visible:=true;
ChartTool1.XValue:= PCAChartGrid.Series.XValue[PCAChartGrid.row-2];
Charttool1.YValue:=PCAChartGrid.Series.YValue[PCAChartGrid.row-2];
procedure TForm1.ChartGridMouseUp(Sender: TObject; Button: TMouseButton;
ChartTool1.Visible:=False;
I cant find how to set the z value? it appears to be set somewhere, but it is not related to the point selected
Richard
Re: Cursor tool in 3d
Post by Yeray » Fri May 10, 2013 1:10 pm
Hi Richard,
I'm not sure about what series type are you using and how would you like the cursor to be drawn.
The following is a 2D chart, but it seems to work fine for me here:
uses Series, TeeTools;
  Chart1.View3D:=false;
  Chart1.Legend.Visible:=false;
  Chart1.AddSeries(TPointSeries).FillSampleValues;
  with Chart1.Tools.Add(TCursorTool) as TCursorTool do
    Chart1.Draw;
    Visible:=false;
  ChartGrid1.Chart:=Chart1;
  ChartGrid1.Series:=Chart1[0];
procedure TForm1.ChartGrid1MouseDown(Sender: TObject; Button: TMouseButton;
  with Chart1.Tools[0] as TCursorTool do
    Visible:=true;
    XValue:=ChartGrid1.Series.XValue[ChartGrid1.row-2];
    YValue:=ChartGrid1.Series.YValue[ChartGrid1.row-2];
procedure TForm1.ChartGrid1MouseUp(Sender: TObject; Button: TMouseButton;
  Chart1.Tools[0].Visible:=False;
Could you please modify the code above so we can get a simple example project we can run as-is to reproduce the problem here?
Richard
Post by Richard » Fri May 10, 2013 4:03 pm
Sorry I should have said, it is on various types of series
TBubble3DSeries
TPoint3DSeries
and TVector3dSeries
You can see the effect on the snap style demo in the teechart 2012
If you try to move the cursor over say the top, back, right point (Light brown for me) - the cursor is not in line with the point because it is well forward of the data point on the depth axis. Toggling the use z button just moves it back slightly NOT to the where the point is in 3D
I hope that makes sense
Richard
Post by Yeray » Mon May 13, 2013 10:27 am
Hi Richard,
Right, the TCursorTool isn't calculating the Z Position when linked to a 3D series, it uses StartZ.
I've implemented it for the next maintenance release (TV52016570).
Richard
Post by Richard » Mon May 20, 2013 10:06 am
Thank - sorry I didn't get back sooner
Any idea when the maintenance release is likely? I know you can't be exact, but a rough idea would help
Thanks again
Richard
Post by Narcís » Mon May 20, 2013 10:15 am
Hi Richard,
It's imminent. We expect to publish it before the end of the week. Stay tuned!
Richard
Post by Richard » Tue May 21, 2013 8:50 am
Great - I will keep lurking here then
R
