problem with radar
problem with radar
I create a radar in TChart and put it on a JPanel,
When i change the size of panel,
the radar will change the size of itself. However,in a wrong way.
When I compare the radar with the radar generated by excel,
this confirm my judge.
Could you please tell me how to address this problem?
Re: problem with radar
Could you please post some screenshots of the problem and a simple example project we can run as-is to reproduce the problem here?
My code is as follows.
In the attachment, you can find two png files.
In the first png (radar1.png), you will see the radar graph is wrong.
In the second png(radar2.png), you will find that the value "33" is not showed correctly either.
Thus, when user changes the size of the dialog, the radar graph changes in a wrong mode.
import com.steema.teechart.Dimension;
import com.steema.teechart.Rectangle;
import com.steema.teechart.editors.ChartEditor;
import com.steema.teechart.styles.Radar;
import java.awt.event.ActionEvent;
import java.awt.event.ActionListener;
import javax.swing.JDialog;
import javax.swing.JMenuItem;
import javax.swing.JPopupMenu;
* @author
public class TestTeeChartJunit extends JDialog {
public TestTeeChartJunit() {
this.setDefaultCloseOperation(JDialog.DISPOSE_ON_CLOSE);
setSize(new Dimension(581, 380));
setTitle("TeeChart for Java - Swing example application");
tChart2 = new TChart();
tChart2.setGraphics3D(null);
// tChart2.addSeries(new Line());
// tChart2.getSeries(0).fillSampleValues(); //随机数
// tChart2.addSeries(new Bar());
// tChart2.getSeries(0).add(10);
// tChart2.getSeries(1).add(13);
// tChart2.getSeries(2).add(49);
// tChart2.getSeries(3).add(55);
Radar series2 = new com.steema.teechart.styles.Radar(tChart2.getChart());
series2.add(50); series2.add(33); series2.add(56); series2.add(88);series2.add(108);
tChart2.setBounds(new Rectangle(0, 0, 500, 500));
//设置图标的属性
tChart2.getAspect().setView3D(false); // no 3D
// tChart2.getLegend().setText("jw legend");
this.add(tChart2);
tChart2.setComponentPopupMenu(popup);
JMenuItem item = new JMenuItem("Property");
item.addActionListener(new RightListener(tChart2));
popup.add(item);
this.setVisible(true);
TestTeeChartJunit myChart = new TestTeeChartJunit();
TChart tChart2;
JPopupMenu popup = new JPopupMenu();
class RightListener implements ActionListener {
TChart tChart2 = null;
public RightListener(TChart chart) {
this.tChart2 = chart;
public void actionPerformed(ActionEvent e) {
ChartEditor.editChart(tChart2.getChart());
- radar2.png (62.15 KiB) Viewed 32706 times
- radar1.png (54.18 KiB) Viewed 32695 times
Gives me this:
That looks as your radar1.png image. However, I'm not sure to find any alternative in your code to generate the radar2.png.
Also, in radar2.png I think the value "33" is drawn correctly. Note it's the lower value in the series, so the axis minimum starts on it by default, so it's drawn on the center.
Then, adding this:
I think will give you the expected result for radar1.png.
And adding this:
I think will draw the "33" where you'd expect.
This code:rubby wrote:In the first png (radar1.png), you will see the radar graph is wrong.
Radar series1 = new Radar(tChart1.getChart());
series1.add(50);
series1.add(33);
series1.add(56);
series1.add(88);
series1.add(108);
Then, adding this:
series1.setCircled(true);
And adding this:
series1.getVertAxis().setAutomaticMinimum(false);
series1.getVertAxis().setMinimum(0);
Thanks Yeray , my problem is addressed.
I still find that radar graph of teechart is different from the excel radar.
one is anticlockwise, the other is clockwise .
I do not find any method to set the radar graph of teechat to clockwise.
Does it exist?
thank you.
Does it exist?
thank you.
Hi rubby,
There's setClockWiseLabels for that. It should reverse the painting order of series and labels but it's not working so I have added it [ID450] to the bug list to be fixed.
I encounter a strange problem with radar graph.
the axis is not in the right position.【radar axis wrong position.png】
what i need it the one in the attachment 【radar correct position.png】.
How can i set the current position of this axis by myself.
is it radar.getVertAxis()... or something else?
- radar correct position.png (87.77 KiB) Viewed 32412 times
- radar axis wrong position.png (90.06 KiB) Viewed 32403 times
Hi rubby,
I can not reproduce this. Are those screen-shots made with different TeeChart versions? Otherwise, which settings differ from one chart to the other?
I am sorry for late reply because of something.
This always happens when i saved the radar graph as xml files and import it again (in my software which integrates Teechart).
However, i can not reproduce this problem by a simple example.
this screen-shots use the same and latest version.
I've made a test and the following seems to work fine for me here.
String tmpName = "E:\\tmp\\JavaXML.xml";
//Initialize
private void initChart() {
commander1.setChart(tChart1.getChart());
Random rnd = new Random();
for (int i = 0; i < 2; i++) {
Radar tmpRadar = new Radar(tChart1.getChart());
for (int j = 0; j < 5; j++) {
tmpRadar.add(50+rnd.nextDouble()*25);
tmpRadar.setCircled(true);
tmpRadar.getVertAxis().setMinMax(0, 100);
tmpRadar.getBrush().setVisible(false);
//Export to XML Button
private void jButton1ActionPerformed(java.awt.event.ActionEvent evt) {//GEN-FIRST:event_jButton1ActionPerformed
try {
tChart1.getExport().getData().getXML().save(tmpName);
} catch (IOException e) {
System.out.println(e);
//Clean Chart Button
private void jButton2ActionPerformed(java.awt.event.ActionEvent evt) {//GEN-FIRST:event_jButton2ActionPerformed
tChart1.removeAllSeries();
//Import from XML Button
private void jButton3ActionPerformed(java.awt.event.ActionEvent evt) {//GEN-FIRST:event_jButton3ActionPerformed
try {
tChart1.getImport().getXML().open(tmpName);
} catch (IOException ex) {
System.out.println(ex);
} catch (ClassNotFoundException ex) {
for (int i = 0; i < tChart1.getSeriesCount(); i++) {
if (tChart1.getSeries(i) instanceof Radar) {
Radar tmpRadar = (Radar) tChart1.getSeries(i);
tmpRadar.getVertAxis().setAutomaticMinimum(false);
tmpRadar.getVertAxis().setMinimum(0);
tChart1.getAspect().setOrthogonal(true);
thanks for the reply.
I also code some simple examples, but the problem can not happen either.
I would let you know if i get the idea of how to reproduce this problem.
