Xamarin.ios Line 2d chart
Thomas
Post by Thomas » Mon Oct 14, 2013 2:57 pm
Steema.Teechart.Series.Line looks bad in View3d =false mode (especially on retina displays), while in 3d mode looks fine.
A) Density is very low.
B) Part of outside labels on axes are hidden
C) Strange chart look when value is constant
How to solve this problem?
TeeChartNETMonoTouch_v4_13_04_05
Screen Shot 2013-10-14 at 2.31.09 PM.png (8.83 KiB) Viewed 6172 times
Screen Shot 2013-10-10 at 2.31.50 PM.png (30.34 KiB) Viewed 6159 times
Re: Xamarin.ios Line 2d chart
Post by Sandra » Tue Oct 15, 2013 10:51 am
Hello Thomas,
Many thanks for your information. I have added your problem in bug list report with number [TM71016739 ]. We will try to fix it to upcoming versions of TeeChart Xamarin for IOS. On the other hand, at the moment as a workaround, you can set the ZoomSrollStyle as Manual as do in next line of code:
chart3.Chart.Aspect.ZoomScrollStyle = Steema.TeeChart.Drawing.Aspect.ZoomScrollStyles.Manual;
I hope will helps.
Thomas
Post by Thomas » Tue Oct 15, 2013 11:31 am
Thanks. Suggested workaround works perfect
