CircularGauge iOS vs Android/WP7
jjbonastre
Post by jjbonastre » Thu Oct 17, 2013 7:28 am
Hi!
I'm creating a circular gauge with the following code (iOS):
		public static void DrawGaugeChart (TChart tChart, ResourceServiceData data, Rectangle chartBounds, int titleTopMargin, Thickness margin, int orientation)
			Console.WriteLine ("DrawGaugeChart");
			if ((data.ServiceData == null) || (data.AccServiceData == null) || (data.CallData == null) || (data.AccCallData == null))
				return;
			tChart.Series.Clear ();
			tChart.Header.Text = data.Resource.Name;
			tChart.Header.Alignment = MonoTouch.CoreText.CTTextAlignment.Center;
			tChart.Header.Font.Size = 16;
			tChart.SubHeader.Visible = false;
			tChart.AfterDraw += tChart_AfterDraw;
			var gauge = new CircularGauge ();
			gauge.Value = data.ServiceData.ServiceData [0].LevelService;
			gauge.LinearGauge.Visible = true;
			gauge.AutoValueLinearGauge = false;
			gauge.LinearGauge.Value = data.AccServiceData.ServiceData [0].LevelService;
			switch (orientation) {
			case 0:
				gauge.CustomBounds = new Rectangle (margin.Left, margin.Top + titleTopMargin, chartBounds.Width / 2 - margin.Left - margin.Right, chartBounds.Height / 2 - margin.Top - margin.Bottom - titleTopMargin);
				break;
			case 1:
				gauge.CustomBounds = new Rectangle (margin.Left, margin.Top + titleTopMargin, chartBounds.Width / 4 - margin.Left - margin.Right, chartBounds.Height - margin.Top - margin.Bottom - titleTopMargin);
				break;
			Console.WriteLine ("ServiceLevel: " + gauge.CustomBounds);
			if (data.IsServiceLevelAlarm) {
				gauge.FaceBrush.Gradient.Direction = GradientDirection.TopBottom;
				gauge.FaceBrush.Gradient.UseMiddle = false;
				gauge.FaceBrush.Gradient.StartColor = UIColor.FromRGBA (161, 161, 161, 255).CGColor;
				gauge.FaceBrush.Gradient.EndColor = UIColor.Red.CGColor;
				gauge.LinearGauge.ValueAreaBrush.Solid = true;
				gauge.LinearGauge.ValueAreaBrush.Color = UIColor.FromRGBA (161, 161, 161, 255).CGColor;
				gauge.LinearGauge.ValueAreaBrush.Visible = true;
			} else {
				gauge.FaceBrush.Gradient.EndColor = UIColor.Green.CGColor;
			var limit = data.ServiceLevelLimit;
			if (limit == 0) {
				gauge.GreenLineStartValue = 90;
				gauge.GreenLineEndValue = 100;
				gauge.RedLineStartValue = 0;
				gauge.RedLineEndValue = 90;
			} else {
				if (limit > 0) {
					gauge.GreenLineStartValue = 0;
					gauge.GreenLineEndValue = limit;
					gauge.RedLineStartValue = limit;
					gauge.RedLineEndValue = 100;
				} else {
					gauge.GreenLineStartValue = Math.Abs (limit);
					gauge.RedLineEndValue = Math.Abs (limit);
			tChart.Series.Add (gauge);
			int attentionLevelAcc = 100;
			int attentionLevelInt = 100;
			if (data.AccCallData.CallsData [0].NumberAnsweredCalls > 0) {
				attentionLevelAcc = (int)(data.AccCallData.CallsData [0].NumberUnderThresholdAnsweredCalls * 100 / data.AccCallData.CallsData [0].NumberAnsweredCalls);
			if (data.CallData.CallsData [0].NumberAnsweredCalls > 0) {
				attentionLevelInt = (int)(data.CallData.CallsData [0].NumberUnderThresholdAnsweredCalls * 100 / data.CallData.CallsData [0].NumberAnsweredCalls);
			gauge.Value = attentionLevelInt;
			gauge.LinearGauge.Value = attentionLevelAcc;
			case 0:
				gauge.CustomBounds = new Rectangle (margin.Left + chartBounds.Width / 2, margin.Top + titleTopMargin, chartBounds.Width / 2 - margin.Left - margin.Right, chartBounds.Height / 2 - margin.Top - margin.Bottom - titleTopMargin);
				break;
			case 1:
				gauge.CustomBounds = new Rectangle (margin.Left + chartBounds.Width / 4, margin.Top + titleTopMargin, chartBounds.Width / 4 - margin.Left - margin.Right, chartBounds.Height - margin.Top - margin.Bottom - titleTopMargin);
				break;
			Console.WriteLine ("AttentionLevel: " + gauge.CustomBounds);
			if (data.IsAttentionLevelAlarm) {
			} else {
			limit = data.AttentionLevelLimit;
			if (limit == 0) {
			} else {
				if (limit > 0) {
				} else {
			gauge.Value = data.ServiceData.ServiceData [0].LevelAbandon;
			gauge.LinearGauge.Value = data.AccServiceData.ServiceData [0].LevelAbandon;
			case 0:
				gauge.CustomBounds = new Rectangle (margin.Left, margin.Top + titleTopMargin + chartBounds.Height / 2, chartBounds.Width / 2 - margin.Left - margin.Right, chartBounds.Height / 2 - margin.Top - margin.Bottom - titleTopMargin);
				break;
			case 1:
				gauge.CustomBounds = new Rectangle (margin.Left + chartBounds.Width / 2, margin.Top + titleTopMargin, chartBounds.Width / 4 - margin.Left - margin.Right, chartBounds.Height - margin.Top - margin.Bottom - titleTopMargin);
				break;
			Console.WriteLine ("AbandonLevel: " + gauge.CustomBounds);
			if (data.IsAbandonLevelAlarm) {
			} else {
			limit = data.AbandonLevelLimit;
			if (limit == 0) {
				gauge.GreenLineEndValue = 10;
				gauge.RedLineStartValue = 10;
			} else {
				if (limit > 0) {
				} else {
			gauge.Value = data.ServiceData.ServiceData [0].Speaking;
			gauge.LinearGauge.Value = data.AccServiceData.ServiceData [0].Speaking;
			case 0:
				gauge.CustomBounds = new Rectangle (margin.Left + chartBounds.Width / 2, margin.Top + titleTopMargin + chartBounds.Height / 2, chartBounds.Width / 2 - margin.Left - margin.Right, chartBounds.Height / 2 - margin.Top - margin.Bottom - titleTopMargin);
				break;
			case 1:
				gauge.CustomBounds = new Rectangle (margin.Left + 3 * chartBounds.Width / 4, margin.Top + titleTopMargin, chartBounds.Width / 4 - margin.Left - margin.Right, chartBounds.Height - margin.Top - margin.Bottom - titleTopMargin);
				break;
			Console.WriteLine ("Speaking: " + gauge.CustomBounds);
			if (data.IsSpeakingLevelAlarm) {
			} else {
			limit = data.SpeakingLevelLimit;
			if (limit == 0) {
			} else {
				if (limit > 0) {
				} else {
			tChart.Hidden = false;
		private static void GetSeriesMark (Series series, GetSeriesMarkEventArgs e)
			var value = series.GetMarkValue (e.ValueIndex);
			if (value > 0) {
				e.MarkText = value + "";
			} else {
				e.MarkText = "";
			int fontSize = 12;
			int subTitleTopMargin = 0;
			RectangleF chartBounds = ContentView.Bounds;
			string text = NSBundle.MainBundle.LocalizedString ("Service Level","");
			PointF p = new PointF(0, 0);
			UIColor.White.SetColor();
			g.Font.Color = UIColor.White.CGColor;
			g.Font.Size = fontSize;
			g.Pen.Color=UIColor.White.CGColor;
			if ((UIDevice.CurrentDevice.Orientation == UIDeviceOrientation.LandscapeLeft) || (UIDevice.CurrentDevice.Orientation == UIDeviceOrientation.LandscapeRight)) {
				p = new PointF (chartBounds.Width / 4 / 2 - (g.TextWidth (text) / 2), titleTopMargin + subTitleTopMargin + (g.TextHeight (text) / 2));
			} else {
				p = new PointF(chartBounds.Width / 2 / 2 - (g.TextWidth(text) / 2), titleTopMargin + subTitleTopMargin + (g.TextHeight(text) / 2));
			g.TextOut(Convert.ToInt32(p.X), Convert.ToInt32(p.Y), text);
			text = NSBundle.MainBundle.LocalizedString ("Attention Level","");
				p = new PointF(chartBounds.Width / 4 / 2 - (g.TextWidth(text) / 2) + chartBounds.Width / 4, titleTopMargin + subTitleTopMargin + (g.TextHeight(text) / 2));
			} else {
				p = new PointF(chartBounds.Width / 2 / 2 - (g.TextWidth(text) / 2) + chartBounds.Width / 2, titleTopMargin + subTitleTopMargin + (g.TextHeight(text) / 2));
			g.Font.Color = ThemeManager.GraphSubTitleColor.CGColor;
			text = NSBundle.MainBundle.LocalizedString ("Abandon Level","");
				p = new PointF(chartBounds.Width / 4 / 2 - (g.TextWidth(text) / 2) + chartBounds.Width / 2, titleTopMargin + subTitleTopMargin + (g.TextHeight(text) / 2));
			} else {
				p = new PointF(chartBounds.Width / 2 / 2 - (g.TextWidth(text) / 2), chartBounds.Height / 2 + titleTopMargin + subTitleTopMargin + (g.TextHeight(text) / 2));
			text = NSBundle.MainBundle.LocalizedString ("Speaking","");
				p = new PointF(3 * chartBounds.Width / 4 + chartBounds.Width / 4 / 2 - (g.TextWidth(text) / 2), titleTopMargin + subTitleTopMargin + (g.TextHeight(text) / 2));
			} else {
				p = new PointF(chartBounds.Width / 2 / 2 - (g.TextWidth(text) / 2) + chartBounds.Width / 2, chartBounds.Height / 2 + titleTopMargin + subTitleTopMargin + (g.TextHeight(text) / 2));
Result:
Quite different from the Windows Phone or Android version:
Problem 1: In iphone there's no way I can paint the chart after draw with a white color. Any suggestion?
Problem 2: If I try to use UIColor.Gray an exception is thrown. I solved this using UIColor.FromRGBA (161, 161, 161, 255) instead.
Problem 3: The gauges don't look really pretty in iOS. Is there any way to make them look like the Android/Phone versions?
The code is similar in windows phone, but replacing Color types with the appropriate ones.
Thanks!
Re: CircularGauge iOS vs Android/WP7
Post by Sandra » Thu Oct 17, 2013 5:07 pm
Hello jjbonastre,
We have reproduced your problem and we have already fixed it. If you have the source code version, we can give you the code to solution the bug. For this reason, could you tell us if you have the source code of TeeChart Xamarin Ios?
jjbonastre
Post by jjbonastre » Fri Oct 18, 2013 9:00 am
Hi!
We have the license for the source code version. If you can provide the patch that would be great. Thanks!
Post by Pep » Fri Oct 18, 2013 9:07 am
Hi jjbonastre,
I've just sent a mail directly to you which includes the fixed file, and also the new dll compiled with latest source files.
Please, do not hesitate to contact us in the case you still having problems.
