Point Series Legend
asupriya
Point Series Legend
Post by asupriya » Tue Oct 22, 2013 11:16 am
Here we are uploading our new sample project. Where , you can see the series style as points in the form of sets of red triangle & green circles. That are displayed in the graph as the channel placement. Where, we want the legend to show up the information only about the channel & not how many points added for that channel in the graph
For an example, see the screenshot "Point Graph.jpg" that a channel has different points displayed as green circles 9times & other channel has different points displayed as red triangle 10 times, But the Legend should sort out only the channels available in it & not the duplicates of it.
So, tell us how to get only the channel name on the legends, when each channel has the series style as points?
Question 2:- If you see the screen shot "Point Graph.jpg". You will see the Y-axis values on the Y-axis. When the user want to display the graph within some Y-axis range e.g. between 35-45 value on Y-axis. We want that Left Grid as visible at the top Y-axis value (45) & at the bottom Y-axis value (35) only and not between that range. Suggest Us?
Note : TChart Version number is 3.5.3700.30575
Thanking you
Screen shot
Point Graph.jpg (165.95 KiB) Viewed 6882 times
SampleTeeCart.7z
Sample Project
(10.83 KiB) Downloaded 758 times
Re: Point Series Legend
Post by Sandra » Thu Oct 24, 2013 2:37 pm
Hello asupriya,
I have modified your code, so instead of you there are 19 series there are two series, one with 9 times and other with 10 times. I think this change do the code works in your end.
You must use custom label to achieve as you want. I have incorporated this in your code.
Please check if the attached project works in your end.
To check the functionality of range, checked and unchecked the checkbox of SetMinMax
SampleTeeCart.zip
(20.58 KiB) Downloaded 760 times
