Labels and Titles way too large when printing
I habe an MS Access application with a integrated linechart both on a preview form and a printed report.
All label and title sizes are defined at runtime and share the same code. Graph title is a label on Access report.
Up to TeeChart 2012 everything works fine. With the latest 2013 version the preview form looks as before
but the printed report has grossly oversized labels and titles.Reverting to 2012 resolves the problem.
Also, PDF created with 2012 is 78 KB, with 2013 3802 KB and the printer usually returns a memory error.
Strangely, the file information on the 2013.ocx shows some rather dated version information.
Thanks for your help,
Andreas
Andreas
- Screen 2013
- Screen_2013ocx.jpg (349.23 KiB) Viewed 39045 times
- Print 2013
- Print_2013ocx.jpg (368.9 KiB) Viewed 38988 times
- Print 2012
- Print_2012ocx.jpg (340.3 KiB) Viewed 38993 times
Re: Labels and Titles way too large when printing
I'm trying to reproduce the problem here but I can't. Can you please arrange a simple example project we can run as-is to reproduce the problem here?
Yeray,
My project is pretty large and retrieves it's data from MS SQL Server.
I could not yet get around to make a sample Database.
Will get back on this in 2 weeks.
Best regards,
Andreas
Best regards,
Andreas
Hi Andreas,
If the data isn't relevant, you could try just with FillSampleValues or a simple routine adding some points.
It took me a while to produce the Test database.
It is an Access 2003-DB and has 1 form and 1 report.
Just open them.
The form is always fine unless you want to print it.
Andreas
Just open them.
Andreas
- Test_TeeChart1.zip
- (114.45 KiB) Downloaded 1804 times
Hi Andreas,
Thanks for the example. I can not run it due to missing Codejock.Controls.v15.0.2.ocx. However, the issue most likely is the same as discussed here: http://bugs.teechart.net/show_bug.cgi?id=69. This will be included in the following TeeChart Pro ActiveX maintenance release.
Hi Narcís
The description fits my problem.
Also I have built a modified example
with the Codejock reference removed.
Andreas
Andreas
- Test_TeeChart2.zip
- (130.42 KiB) Downloaded 1766 times
Hi Andreas,
Thanks for your feedback. I could reproduce the issue with your file now. We exepct the fix being included for the next maintenance release. If you are interested, we could send you a test .ocx.
Hi Narcís
I'd gladly test the revised ocx on my full project.
Best regards,
Andreas
Best regards,
Andreas
Hi Andreas,
Ok, just sent you a test .ocx to your forums profile email address.
Hi Narcis
Thanks for your test OCX.
We are not quite there yet - see the enclosed JPEG's.
Please note that that title and footer text
are directly on the MS Access form/report,
not on the TeeChart control.
Best wishes,
Andreas
Best wishes,
Andreas
- TeeChart2014_Print.jpg (222.24 KiB) Viewed 38824 times
- TeeChart2014_Screen.jpg (165.02 KiB) Viewed 38840 times
Hi Andreas,
Could you please attach the new example project?
Hi Narcís
I used my production tool to produce the images.
So here's my Test.mdb modified to work with your Test.ocx.
The symptoms are the same.
Best wishes,
Andreas
Best wishes,
Andreas
- Test_TeeChart3.rar
- (94.86 KiB) Downloaded 1872 times
Hi Andreas,
We are investigating the issue here. In the meantime, a workaround is disabling GDI+ in your chart:
TChart1.Aspect.GDIPlus.Active = False
Hi Narcis
Are there any news on this?
Disabling GDI+ is a momentary workaround but printouts are not really satisfactory ...
I could also live with an older fully functional 2013 Version for the moment.
Best wishes,
Andreas
Best wishes,
Andreas
