GaugeSeriesPointer is not marked as serializable
acastro
Post by acastro » Fri Nov 08, 2013 9:21 am
I have recently upgrade Teechart from a two years old version, and I have this error, in a code which runs before the upgrade.
Re: GaugeSeriesPointer is not marked as serializable
Post by Sandra » Fri Nov 08, 2013 4:06 pm
Hello wakeup,
Next code works in correct way for me:
  Steema.TeeChart.Styles.Line line1;
    Steema.TeeChart.Styles.GaugeSeriesPointer gauge;
     line1 = new Line(tChart1.Chart);
      gauge = new GaugeSeriesPointer(tChart1.Chart, line1);
      line1.FillSampleValues();
      line1.Pointer.Visible = true;
      tChart1.Export.Template.Save(@"C:\test.tmp");
      line1.GetPointerStyle += line1_GetPointerStyle;
      button1.Click += button1_Click;
    void line1_GetPointerStyle(CustomPoint series, GetPointerStyleEventArgs e)
      gauge.Draw(line1.CalcXPos(1), line1.CalcYPos(1), Color.Red);
Could you check if my code works for you?
acastro
Post by acastro » Fri Nov 08, 2013 4:42 pm
It runs, but try this example project
http://193.145.251.126/pnp/files/Xmutyz ... chart2.zip
Push button1, and then button2. I get the error in button 2.
Post by Sandra » Mon Nov 11, 2013 12:20 pm
Hello wakeup,
Thanks for extra information. I can reproduce this problem, I have added it in bug list report with number [id90]. We will try to fix it to upcoming versions of TeeChartfor.Net. Remember you can follow the status of the bug in this link.
On the other hand, could you tell us in which version it works fine for you?
acastro
Post by acastro » Mon Nov 11, 2013 12:31 pm
My previous version was
TeeChartNET2010VSNET2010_4.0.2010.13053.exe
Post by Sandra » Mon Nov 11, 2013 12:44 pm
Hi wakeup,
Many thanks.
