My data is read from a CSV (Comma Separated Variable)file.
I'm having trouble getting the correct time to display in the bottom axis.
I'm getting 12:00:00 for every Time Mark label on the grid in the X axis.
The time format in the CSV file is this (based on 24 hour clock):
111458
11 = 11am
14 = 14 minutes
58 = 58 seconds
The left most side (Minimum) of the bottom axis should start at 111458.
I have 2 modes of graphing:
1) Hourly
I need the Right most side (Maximum) to be 65 minutes later - 121958 (as a default span at startup), and should be displayed as 11:14:58.
As the number/value of time points increments, once the value is start+60mins., begin shiftingthe entire graph to the left by 5 mins. and displayed as 12:19:58
2) Entire length of data
The left most side (Minimum) of the bottom axis should start at 111458, and the rightmost(Maximum) to be what ever the last time stamp in the file is (in this case, it's 111807).
Again, the Minimum shoud be displayed as 11:14:58, and the Maximum should be displayed as 11:18:07
In both cases, the number of time mark labels need to be selectable by the user in ranges of 1 sec, 1 min. 5 min, 30min, 1 hour, 4 hours, 8 hours, 12 hours, 24 hours, days, weeks.
These should be easy, but they have me whipped!
Thanks!
Setting bottom axis to decimal time read from CSV File.
Re: Setting bottom axis to decimal time read from CSV File.
Hello triby,
Thanks for information. Could you send us your data file, so we can working with your data and suggest you a good solution for you?
Thanks Sandra!
Here's the data file.
- DataFile.Zip
- (4.29 KiB) Downloaded 762 times
Hello Triby,
Thanks for your Data. I have made a simple code where try to achieve as you want and you can apply it in your project with your data:
Could you please tell us if previous code works in your end? Could you tell if you can can apply it in your code?
I hope will helps.
InitializeChart();
Steema.TeeChart.Styles.FastLine Series1, Series2;
DateTime dt;
Series1 = new FastLine(tChart1.Chart);
// Series2 = new FastLine(tChart1.Chart);
dt = new DateTime(DateTime.Now.Year, DateTime.Now.Month, DateTime.Now.Day, 11, 14, 58);
Random rnd = new Random();
for (int i = 0; i < 13; i++)
Series1.Add(dt, rnd.Next(100));
dt = dt.AddMinutes(5);
tChart1.Axes.Bottom.SetMinMax(DateTime.FromOADate(Series1.XValues.First), new DateTime(DateTime.Now.Year, DateTime.Now.Month, DateTime.Now.Day, 12, 19, 58));
tChart1.Axes.Bottom.Labels.DateTimeFormat = "hh:mm:ss";
tChart1.Axes.Bottom.Labels.Style = Steema.TeeChart.AxisLabelStyle.PointValue;
I hope will helps.
Sandra,
I get moved from 1 project to another quite often as what happened with this one.
I am now back on it and so I'm picking up where I left off.
I have copied the code you provided here into a test project.
The very last line of code is a problem:
The .PointValue is not a property of the AxisLabelStyle.
I commented out this line, but I fear it needs something in it's place.
Can you re-visit this issue so I can move forward?
Thanks!
Thanks!
Also, with respect to the Data file; my code strips out the Quotes prior to using the data.
Hello tirby,
Is possible the PointValue property doesn't exist in your version of TeeChartFor.Net.
What version of TeeChartFor.Net are you using?
On the other hand, an alternative for your problem is, use custom labels as I have done in next code:
Could you tell us if previous code with your data, works in your end? If it doesn't work please, try to arrange for us a simple project, because we can reproduce your exactly problem and try solution for you.
InitializeChart();
Steema.TeeChart.Styles.FastLine Series1;
DateTime dt;
for (int i = 0; i < 13; i )
for (int i = 0; i < Series1.Count; i )
tChart1.Axes.Bottom.Labels.Items.Add(Series1.XValues[i], DateTime.FromOADate(Series1.XValues[i]).ToString("hh:mm:ss"));
