Migrate V8 to V2013 Pb size texte
TeeTree VCL for Borland Delphi and C++ Builder.
mivtee
Post by mivtee » Thu Jan 16, 2014 2:13 pm
I just migrated from v8 in v2013 and the installation correct without Pb.
In my application the nodes is plotted normally, but the size of the texte (caption of node is lowercase, lowercase like not visible) then is about 12.
There is a setting in TeeTree v2013 to for proportionnal texte ?
Copy screen result draw node
PB_Teetree size texte.jpg (7.76 KiB) Viewed 63023 times
Re: Migrate V8 to V2013 Pb size texte
Post by Yeray » Fri Jan 17, 2014 9:50 am
Could you please arrange a simple example project we can run as-is top reproduce the problem here?
Also please tell us what exact TeeChart and IDE versions are you using.
mivtee
Post by mivtee » Fri Jan 17, 2014 5:25 pm
I find the PB
i my code i have old error (10 years) because i setting "Height" properties then size
Node.Font.Height := 18 //V8 vcl pro no PB but with V2013 Vcl Pro the result Font.Size= -14 !!
Correct by
Node.Font.size := 18 //and it's good !!
