When we try to do zoom with the scrollpager activated, the square which appears when you do click to do zoom is not well posicionated.
By example
http://193.145.251.126/pnp/files/bpYFbf ... Scroll.zip
If you press button10 and then button1, and try to do zoom the squuare is not well positionated, but if the window is maximized it is well.
Scrollpager and zoom
- Guru
Re: Scrollpager and zoom
As a workaround to this, try:wakeup wrote:If you press button10 and then button1, and try to do zoom the squuare is not well positionated, but if the window is maximized it is well.
tChart1.Axes.Bottom.Labels.DateTimeFormat = "dd/MM/yyyy HH:mm";
tChart1.Zoom.FullRepaint = true;
tChart1.Zoom.Pen.Color = Color.Red;
Thanks it runs.
Another question... When I activate the scrollpager the zoom direction is changed from both to horizontal. Why this behaviour? If I set manually again to both it seems to run well also with scrollpager...
- Guru
This behaviour is by design. The rationale behind this behaviour is that only the horizontal movements of the top chart are reflected in the bottom chart (the 'scrollpager' one). As you have discovered, this default behaviour can be overwritten.wakeup wrote:Another question... When I activate the scrollpager the zoom direction is changed from both to horizontal. Why this behaviour? If I set manually again to both it seems to run well also with scrollpager...
Sometimes I see the efect of the screenshot, and I noticed it is due to FullRepaint. Can I avoid this effect dupplicating/triplicationg... the square when using zoom?Christopher wrote:As a workaround to this, try:wakeup wrote:If you press button10 and then button1, and try to do zoom the squuare is not well positionated, but if the window is maximized it is well.Code: Select all
private void Form1_Load(object sender, EventArgs e) { tChart1.Aspect.View3D = false; tChart1.Axes.Bottom.Labels.DateTimeFormat = "dd/MM/yyyy HH:mm"; tChart1.Zoom.FullRepaint = true; tChart1.Zoom.Pen.Color = Color.Red; }
- fullrepaint.png (42.48 KiB) Viewed 15224 times
Hi wakeup,
Can you please attach a simple example project we can run "as-is" and let us know the exact steps we should follow to reproduce the problem here? The link in your first post is no longer valid.
http://193.145.251.126/pnp/files/ZhRPwi ... chart3.zip
Press button1, and then move the mouse with left button clicked to set the zoom
Hi wakeup,
This is a bug, I'm afraid. Please feel free to add it to bugzilla. Doing so you'll receive automatic notifications on any issue update.
