Scrollpager and zoom
acastro
Post by acastro » Fri Feb 21, 2014 11:58 am
When we try to do zoom with the scrollpager activated, the square which appears when you do click to do zoom is not well posicionated.
By example
http://193.145.251.126/pnp/files/bpYFbf ... Scroll.zip
If you press button10 and then button1, and try to do zoom the squuare is not well positionated, but if the window is maximized it is well.
Re: Scrollpager and zoom
Post by Christopher » Fri Feb 21, 2014 12:32 pm
wakeup wrote:If you press button10 and then button1, and try to do zoom the squuare is not well positionated, but if the window is maximized it is well.
As a workaround to this, try:
            tChart1.Axes.Bottom.Labels.DateTimeFormat = "dd/MM/yyyy HH:mm";
            tChart1.Zoom.FullRepaint = true;
            tChart1.Zoom.Pen.Color = Color.Red;
acastro
Post by acastro » Fri Feb 21, 2014 12:51 pm
Thanks it runs.
Another question... When I activate the scrollpager the zoom direction is changed from both to horizontal. Why this behaviour? If I set manually again to both it seems to run well also with scrollpager...
Post by Christopher » Fri Feb 21, 2014 1:06 pm
wakeup wrote:Another question... When I activate the scrollpager the zoom direction is changed from both to horizontal. Why this behaviour? If I set manually again to both it seems to run well also with scrollpager...
This behaviour is by design. The rationale behind this behaviour is that only the horizontal movements of the top chart are reflected in the bottom chart (the 'scrollpager' one). As you have discovered, this default behaviour can be overwritten.
acastro
Post by acastro » Wed Jun 25, 2014 1:41 pm
Sometimes I see the efect of the screenshot, and I noticed it is due to FullRepaint. Can I avoid this effect dupplicating/triplicationg... the square when using zoom?
Post by Narcís » Wed Jun 25, 2014 1:51 pm
Hi wakeup,
Can you please attach a simple example project we can run "as-is" and let us know the exact steps we should follow to reproduce the problem here? The link in your first post is no longer valid.
acastro
Post by acastro » Wed Jun 25, 2014 1:56 pm
http://193.145.251.126/pnp/files/ZhRPwi ... chart3.zip
Press button1, and then move the mouse with left button clicked to set the zoom
Post by Narcís » Wed Jun 25, 2014 2:59 pm
Hi wakeup,
This is a bug, I'm afraid. Please feel free to add it to bugzilla. Doing so you'll receive automatic notifications on any issue update.
