Exception when loading 3D chart
mivtee
Post by mivtee » Wed Mar 19, 2014 9:02 am
I have an exception when I add data in a TSurfaceSeries. I have joined a little project.
EDI is Delphi 2007 and Chart version is TeechartPro V2013.09.
Chart3D.zip
(12.8 KiB) Downloaded 693 times
Re: Exception when loading 3D chart
Post by Narcís » Fri Mar 21, 2014 9:46 am
Hi mivtee,
I can not reproduce the problem here using v2014.10.140220, which is the latest version available. Can you please check if this solves the problem at your end?
BTW, I'm not getting anything displayed in the chart though. Please bear in mind that Surface series should have a structure similar to what I described here.
mivtee
Post by mivtee » Fri Mar 21, 2014 2:06 pm
I didn't find a v2014.10.140220 for Delphi 2007, where can I download it?
It works with this code:
     for x:=0 to 32 do
      (Serie as TSurfaceSeries).AddXYZ(x,random,1);
    for x:=0 to 32 do
      (Serie as TSurfaceSeries).AddXYZ(x,random,2);
I have this result:
But this doesn't work and make an exception:
     for x:=0 to 32 do
    for x:=0 to 30 do
Chart3DV2.zip
(13.54 KiB) Downloaded 732 times
Post by Yeray » Fri Mar 21, 2014 4:11 pm
Hi mivtee,
I see in your dfm you have two TChart components overlapping. One has a TSurfaceSeries and the other has a TIsoSurfaceSeries.
I removed both and added a new one and created a TIsoSurfaceSeries by code.
I can reproduce the problem with v2013.09 but not with v2014.10. I attached the simplified version FYI:
Chart3DV2.zip
(1.76 KiB) Downloaded 733 times
mivtee wrote:I didn't find a v2014.10.140220 for Delphi 2007, where can I download it?
I've loged in the client area with your license information and I found the v2014.07 installer for RAD 2007:
TeeChart2014Delphi2007.exe
February 24, 2014
Build 2014.10.140220
File size - 50,36 MB
It's the second in the list, after TeeChart2014Delphi7.exe
mivtee
Post by mivtee » Fri Mar 21, 2014 6:52 pm
Sorry, but I didn't see any TeeChart2014Delphi2007.exe in our client area.
Post by Yeray » Mon Mar 24, 2014 11:15 am
mivtee wrote:Sorry, but I didn't see any TeeChart2014Delphi2007.exe in our client area.
You "didn't see" means you do now?
If not, please tell us and we'll send you a mail with the direct link to download it.
mivtee
Post by mivtee » Mon Mar 24, 2014 12:55 pm
hi,
I don't see any TeeChart2014Delphi2007.exe in our client area. So we'll be interesting to have the link to download it.
Regards.
Post by Yeray » Mon Mar 24, 2014 1:07 pm
mivtee wrote:I don't see any TeeChart2014Delphi2007.exe in our client area. So we'll be interesting to have the link to download it.
Just sent.
mivtee
Post by mivtee » Mon Mar 24, 2014 2:38 pm
Thank you, I used the old License/password... So it works now.
regards
