Hi,Yeray
I used colorGrid to make a map.Now I want to draw a line on colorgrid and to create a profile section.Would you give me any suggestions?I do not know how to get the coordinates and values of the intersection points between the line and colorgrid.
Cheers,
Robinson
How to create profile section?
Re: How to create profile section?
Hi robinson,
I've been able to draw a ColorGrid and a Line series in the same chart:
I'm not sure to understand what problem have you found when trying to do it.zrandlbs wrote:I used colorGrid to make a map.Now I want to draw a line on colorgrid and to create a profile section.Would you give me any suggestions?I do not know how to get the coordinates and values of the intersection points between the line and colorgrid.
Private Sub Form_Load()
TChart1.Header.Text.Clear
TChart1.Header.Text.Add TChart1.Version
TChart1.Aspect.View3D = False
TChart1.AddSeries scColorGrid
TChart1.Series(0).FillSampleValues
TChart1.AddSeries scLine
TChart1.Series(1).FillSampleValues
End Sub
Hi,Yeray,
Thank for your quick reply.I used colorgrid to generate an image that the grid color is concentration of an element.Now I need to allow users to draw a line on my image to generate a section along the line. I need to get values of the colors and coordinates on the line.
Because the line is drawn by users,so I think I should use "draw line" tool.
I think the key problem is how to get the coordinates of crossing points between the drawn line and my image.I drew a picture for you. In my picture,Y axis is concentration of Al and x axis is distance of the drawn line on colorgrid.
Good luck!
Robinson
Good luck!
Robinson
- questionA.jpg (163.56 KiB) Viewed 16973 times
Hi Robinson,
The Clicked(X, Y) function of the ColorGrid will give you the index of the cell under a given pixel. However, you still have to calculate the list of pixels in that line, and I'm afraid you should do it manually. I've taken the code from here to make a simple example. Take it as a start point:zrandlbs wrote:Thank for your quick reply.I used colorgrid to generate an image that the grid color is concentration of an element.Now I need to allow users to draw a line on my image to generate a section along the line. I need to get values of the colors and coordinates on the line.
Private Sub Command1_Click()
checkLine
End Sub
TeeCommander1.ChartLink = TChart1.ChartLink
TChart1.Tools.Add tcDrawLine
TChart1.Tools.Items(0).asDrawLine.EnableDraw = False
TChart1.Tools.Items(0).asDrawLine.AddLine 0, 0, 5, 5
'TChart1.Environment.InternalRepaint
'MsgBox TChart1.Tools.Items(0).asDrawLine.Lines.Items(0).EndPos.x
End Sub
Private Sub checkLine()
Dim i, X, tmp As Integer
Dim X0, Y0, X1, Y1 As Integer
X0 = TChart1.Axis.Bottom.CalcXPosValue(TChart1.Tools.Items(0).asDrawLine.Lines.Items(0).StartPos.X)
Y0 = TChart1.Axis.Left.CalcYPosValue(TChart1.Tools.Items(0).asDrawLine.Lines.Items(0).StartPos.Y)
X1 = TChart1.Axis.Bottom.CalcXPosValue(TChart1.Tools.Items(0).asDrawLine.Lines.Items(0).EndPos.X)
Y1 = TChart1.Axis.Left.CalcYPosValue(TChart1.Tools.Items(0).asDrawLine.Lines.Items(0).EndPos.Y)
Dim steep As Boolean
steep = Math.Abs(Y1 - Y0) > Math.Abs(X1 - X0)
If steep Then
tmp = X0
X0 = Y0
Y0 = tmp
tmp = X1
X1 = Y1
Y1 = tmp
End If
If X0 > X1 Then
tmp = X0
X0 = X1
X1 = tmp
tmp = Y0
Y0 = Y1
Y1 = tmp
End If
Dim deltax As Integer
deltax = X1 - X0
Dim deltay As Integer
deltay = Math.Abs(Y1 - Y0)
Dim ERR As Integer
ERR = deltax \ 2
Dim ystep As Integer
Dim Y As Integer
Y = Y0
If Y0 < Y1 Then
ystep = 1
Else
ystep = -1
End If
For X = X0 To X1
If steep Then
List1.AddItem Y & " " & X
Else
List1.AddItem X & " " & Y
End If
ERR = ERR - deltay
If ERR < 0 Then
Y = Y + ystep
ERR = ERR + deltax
End If
For i = 0 To TChart1.Series(0).Count - 1
tmp = TChart1.Series(0).Clicked(X, Y)
If tmp > -1 Then
TChart1.Series(0).PointColor(tmp) = vbRed
End If
Next i
Next
End Sub
