I am using the latest 2014 32 bit VCL with Delphi XE (Windows 7 64 bit) and I noticed that with GDI+ when a back image is defined, the chart slowly redraws (e.g. pan and zoom are slow). If I use the GDI canvas then performance is ok. Does anyone noticed this behavior? Is there a work around? I did try setting back image draw quality to low but this does not help.
Kindest regards
2014 reduced performance with back image
Re: 2014 reduced performance with back image
Ok, here is what I found by mistake After adding a filter to the back image performance looks normal. Attached is a sample project (also notice that the unfiltered image is not displayed correctly)
- Test.zip
- (136.58 KiB) Downloaded 664 times
Thanks for the example project.
I could reproduce both problems here using the latest binary version but they are solves with our current sources:
I can send you a test version so that you can test if it solves the problem at your end.
Hello Narcis,
I can confirm that the test version solves the issue!!! Thank you very much for your prompt reply and support
Kindest regards
Kindest regards
Hi johnnix,
You're very welcome! I'm glad to hear that.
