Point Image
amol
Point Image
Post by amol » Fri May 30, 2014 10:24 am
I need to show a point with attached shape. kindly confirm how can i implement this using teechart.
Point shape
Re: Point Image
Post by Christopher » Fri May 30, 2014 11:22 am
amol wrote:I need to show a point with attached shape. kindly confirm how can i implement this using teechart.
You can use the image itself in an ImagePoint series, or draw it directly onto the canvas, e.g.
      ImagePoint point = new ImagePoint(tChart1.Chart);
      point.PointImage = Image.FromFile(@"C:\tmp\1.png");
      point.Pointer.HorizSize = 30;
      point.Pointer.VertSize = 20;
      point.FillSampleValues();
      tChart1.AfterDraw += tChart1_AfterDraw;
    void tChart1_AfterDraw(object sender, Graphics3D g)
      g.Draw(Utils.FromLTRB(10, 10, 70, 50), Image.FromFile(@"C:\tmp\1.png"), true);
Is that what you meant?
amol
Re: Point Image
Post by amol » Tue Jun 03, 2014 6:45 am
I am not able to give the title of ImagePoint, plz answer this.
Re: Point Image
Post by Christopher » Tue Jun 03, 2014 7:44 am
amol wrote:I am not able to give the title of ImagePoint, plz answer this.
I'm not sure what the problem is here. The following code works as expected, with the series title being correctly displayed in the legend:
      point.PointImage = Image.FromFile(@"D:\tmp\1.png");
      point.Title = "My Point";
      tChart1.Legend.LegendStyle = LegendStyles.Series;
amol
Re: Point Image
Post by amol » Wed Jun 04, 2014 8:03 am
thx it works
amol
Re: Point Image
Post by amol » Tue Jun 10, 2014 7:16 am
Hi ,
I have taken Point not taken ImagePoint and coded then how can i achieve this using Point. plz suggest.
Re: Point Image
Post by Christopher » Tue Jun 10, 2014 10:20 am
amol wrote:Hi ,
I'm sorry, I'm afraid I don't understand your request. Could you please provide some code to show me what you need?
amol
Re: Point Image
Post by amol » Fri Jun 13, 2014 6:30 am
You have taken ImagePoint point = new ImagePoint(tChart1.Chart) in your example but i have taken Point ps=new Point(). i want to achieve same functionality using Point how can i achieve this?
Re: Point Image
Post by Narcís » Fri Jun 13, 2014 7:18 am
Hello amol,
ImagePoint is the specific series style, which is derived from Points series, to plot images as pointers. If you don't want to use ImagePoint series you can achieve almost the same creating your own custom series, deriving it from Points series and overriding its drawing methods as in the example I posted here: http://www.teechart.net/support/viewtopic.php?t=4309
