Problem with filled High-Low Series
Metman
Post by Metman » Mon Jun 16, 2014 8:53 pm
I am having problems setting a color fill in a high-low series. I select a color and set the transparency to 50%, but although this behaves itself in the IDE design view, when I compile and run the transparency is 100% with no color fill.
I have the chart connected to a GDI+ component, but its still transparent when I set GDI+ active to false.
I never had a problem in the v2008 where this feature always worked well.
Bruce.
Re: Problem with filled High-Low Series
Post by Yeray » Tue Jun 17, 2014 12:43 pm
Hi Bruce,
Metman wrote:I am having problems setting a color fill in a high-low series. I select a color and set the transparency to 50%, but although this behaves itself in the IDE design view, when I compile and run the transparency is 100% with no color fill.
Check the paths in the IDE. If you the chart looks different at designtime and at runtime, and no special property is modified by code, it usually indicates there's an entry in the library path pointing to a different installation than the packages loaded with the IDE startup.
Metman wrote:I have the chart connected to a GDI+ component, but its still transparent when I set GDI+ active to false.
Note you don't need to drop a TTeeGDIPlus component anymore.
Metman wrote:I never had a problem in the v2008 where this feature always worked well.
Could you please specify what exact TeeChart version where you using back in 2008?
If you still find problems with this, please try to arrange a simple example project we can run as-is to reproduce the problem here.
Metman
Post by Metman » Tue Jun 17, 2014 2:04 pm
Hi Yeray
I was using v8.08 in Delphi 2007.
I notice that the reference in my library path in Delphi XE6 for TeeChart 2014 is Dephi20.win32\lib.
Shouldn't that be Delphi20.win64 if I'm running Windows 7 64 bit?
Screen shot
Bruce.
Post by Yeray » Tue Jun 17, 2014 2:52 pm
Hi Bruce,
Metman wrote:I was using v8.08 in Delphi 2007.
Thanks for the details. They look correct to me so we'd need that simple project I asked above if you can arrange it so we can try to reproduce the problem here.
Metman
Post by Metman » Tue Jun 17, 2014 3:06 pm
Hi Yeray
I've attached a very simple project.
In the IDE I see this:
When I build and run it I see this:
I have left the transparency off so I should see the color filled area series right?
Bruce.
Chart.zip
(77.83 KiB) Downloaded 981 times
Post by Yeray » Wed Jun 18, 2014 7:43 am
Hi Bruce,
Yeray wrote:Thanks for the details. They look correct to me so we'd need that simple project I asked above if you can arrange it so we can try to reproduce the problem here.
I don't see the "Selected platform" combobox in your image above. See this post to see what are the paths for each platform.
Metman wrote:I've attached a very simple project.
I've opened your project in RAD XE6 here and this is how it looks like for me at design time:
If this project you've attached shows the High-Low series filled at design time for you, it can only be that we have different TeeChart versions installed in our IDEs.
Could you please check the packages list? As per the image of the paths you posted above, selecting the package with description "TeeChart Pro 2014 VCL Components" should show "C:\Program Files (x86)\Steema Software\TeeChart 2014 for RAD XE6\Delphi20.win32\Bin\DclTeePro920.bpl" for you in the text box below the list. For me the path is a bit different because I change the default installation path to not override it with every installation:
As an extra check, please open the Release.txt file from the installation path (C:\Program Files (x86)\Steema Software\TeeChart 2014 for RAD XE6) and check if the build is:
Release Notes 12th May 2014
TeeChart VCL/FMX version 2014
Build 2014.11.140512
Metman
Post by Metman » Wed Jun 18, 2014 10:35 am
HI Yeray
Both things that you asked me to check are the same as on your machine.
I take it that the fills in the high-low series is fine on your PC?
Bruce.
Post by Yeray » Wed Jun 18, 2014 12:57 pm
Thanks for providing all the information requested.
We've found the problem seems to be the HighBrush.Style and LowBrush Style properties seem not to be correctly saved to the dfm.
http://bugs.teechart.net/show_bug.cgi?id=805
The only workaround we can think on at the moment would be to set the property at runtime by code.
Metman
Post by Metman » Wed Jun 18, 2014 3:28 pm
OK Yeray I'll wait for a fix in the next release!
