Chart.draw(); gives error d.toFixed is not a function?
sct
Post by sct » Fri Jul 11, 2014 1:35 pm
I have some code that worked with steema some time last year and I just updated to the saltest. Going through the code to make sure all is in order and ran in to this error. Here is my code leading up to the error. The very last line causes the error.
         this.UIDiv.removeChild( this.canvas );
         this.canvas = document.createElement( 'canvas' );
         this.canvas.id = "canvas" + this.id;
         this.canvas.width = this.canvasData_width;
         this.canvas.height = this.canvasData_height;
         this.canvas.style.zIndex = this.canvasData_zIndex;
        // this.canvas.style.background = "#ffffff"
         this.UIDiv.appendChild( this.canvas );
         this.Chart1 = new Tee.Chart( "canvas" + this.id );
         this.annot = new Tee.Annotation( this.Chart1 );
         this.annot.position.x = 15;
         this.annot.position.y = 20;
         var anno = this.annot
         this.annot.mousemove = function () { this.text = ""; }
         if ( this.type == "Function" ) this.addData( this.Xdata, this.Ydata, .5, "ellipse" );
         else if ( this.type == "Table" )
             for ( z = 0; z < this.Zdata.length;z++ )
                 this.addData( this.Ydata, this.Zdata[z], .5, "ellipse" );
         //this.Chart1.legend.textStyle = "values"
         //this.Chart1.legend.legend_textstyle = "label"
         this.Chart1.tools.add( this.annot );
         this.Chart1.title.text = "";
         this.Chart1.axes.left.title.text = this.labelY;
         this.Chart1.axes.bottom.title.text = this.labelX;
         this.Chart1.tools.add( new Tee.DragTool( this.Chart1 ) ); alert( 5 )
         this.Chart1.draw();
Re: Chart.draw(); gives error d.toFixed is not a function?
Post by Yeray » Fri Jul 11, 2014 3:30 pm
Could you please arrange a simple example we can run as-is to reproduce the problem here?
To attach an htm file you may have to zip it before.
sct
Post by sct » Fri Jul 11, 2014 4:12 pm
this seems to do it.
point.zip
(1.75 KiB) Downloaded 1224 times
Post by Yeray » Mon Jul 14, 2014 11:11 am
It seems to crash because it expects the data to be doubles, not strings, when executing this line with d being the first value in the series "0":
return d.toFixed(0);
I'm trying to identify what change in the sources affected this. Can you tell us in what version did that example work fine?
sct
Post by sct » Mon Jul 14, 2014 12:53 pm
could have something to do with this
(see number 2) "how to use an array without eval'ing it? "
http://www.teechart.net/support/viewtop ... 18&t=14255
I had issues with that before.
This is what I found in the read me
Release Notes 14th December 2012
TeeChart for JavaScript v1.4
Sourcecode version 2012.12.14.1.4
sct
Post by sct » Mon Jul 14, 2014 1:01 pm
I made it work with
this.addData( eval( "["+Xdata +"]"), eval( "["+Ydata+"]" ), .5, "ellipse" );
but not I get this error.
TypeError: text.split is not a function
Post by Yeray » Tue Jul 15, 2014 11:13 am
If the input data is going to be in that format, what about calling addData without changing any type and doing the job inside it?
Ie:
addData( Xdata, Ydata, .5, "ellipse" );
         dat.data.values = eval("["+ydata+"]");
         dat.data.x = eval("["+xdata+"]");
         dat.data.labels = xdata;
sct
Post by sct » Tue Jul 15, 2014 12:46 pm
This works, will this be the best practices or would the API accept text at some point?
Post by Yeray » Tue Jul 15, 2014 3:17 pm
I've added it to the wish list to be further investigated if we can implement some extra code to handle this situation:
http://bugs.teechart.net/show_bug.cgi?id=848
But in the meanwhile I'd consider the developer is the responsible to make sure data.x and data.values will receive arrays of numbers and data.labels will be an array of strings.
sct
Post by sct » Tue Jul 15, 2014 4:48 pm
great thx.
