Blank chart at design time - painted when clicked on
Christian Ziegelt
Post by Christian Ziegelt » Mon Jan 19, 2015 9:40 am
Dear all,
I've got the following problem with the Sept.14 Version of TeeChart Pro.
When designing in XE7 charts become blank. They are no longer painted.
this happens after a few minutes - or when moving the window.
Chart is Blank in designtime
This is not happening always or with each project.
When clicking on the chart in design time (mousedown) the chart is painted as long as the mouse button stays pressed.
If clicking on the chart - While mousedown() the chart is painted
Any idea how to solve this ?
Currently I am not able to check how changes to series / tools / etc. effect the layout.
Christian
Re: Blank chart at design time - painted when clicked on
Post by Yeray » Mon Jan 19, 2015 10:39 am
Hi Christian,
I think we haven't seen this before.
We'd need to reproduce this problem here in order to investigate the cause and try to find a fix for the same.
Does it happen in VCL or in FMX projects?
Taking a project where the problem is reproducible, could you please remove components from the form and tools&series from the chart to get a project as simple as possible while still reproducing the problem so you can send it to us?
Christian Ziegelt
Post by Christian Ziegelt » Mon Jan 19, 2015 1:19 pm
Dear Yeray,
I will try to do it as fast as possible. Unfortunately I am currently lacking the time.
