Blank space issue for Candle Sticks Graph
while drawing Candle Stick Graph in Teechart.Net. When datavalue is not present for particular date it shows blank space (e.g.for Saturday, Sunday and Holiday.). previously when we were using Ocx version the candlestick graph was continuous without any blank space
Kindly see the attached file
- blankSpace.JPG (22.79 KiB) Viewed 30282 times
- Guru
Re: Blank space issue for Candle Sticks Graph
There is an example in the Feature Demo under:Quant wrote:while drawing Candle Stick Graph in Teechart.Net. When datavalue is not present for particular date it shows blank space (e.g.for Saturday, Sunday and Holiday.). previously when we were using Ocx version the candlestick graph was continuous without any blank space
%Program Files%\Steema Software\Steema TeeChart for .NET 201X 4.1.201X.XXXXX\Examples\DemoProject\bin\ExecutableDemo\TeeChartNetExamples.exe
Go to the "All Features tab" and then
Welcome !\Chart styles\Financial\Candle (OHLC)\Axis Labels no Weekends
Thank you for your prompt response. I already gone through that example.
But that workaround of labels will not work for me.
- Guru
Can you please send us the code that worked correctly for you in the OCX version?Quant wrote:Thank you for your prompt response. I already gone through that example.
TChartMain.Series(0).asCandle.AddCandle(dtTemp.ToOADate(), OpenValue, HighValue, LowValue, CloseValue, dtTemp.Date.ToString(), (uint)TeeChart.EConstants.clTeeColor);
- Guru
In TeeChart AX there is a property called "RemoveGaps":
This property is not present in TeeChart .NET, so I have added this property as a feature request with id=1147. In the meantime, the only option is to use the technique I have described, I'm afraid.
Hi Christopher,
We need the same property on urgent basis, since we can not use given workaround for our project. Using integer value in date field makes us compromise most of the user requirements. It also changes our most of the source code which is based on the ActiveX Version of TeeChart.
Please let us know when we can get this functionality.
- Guru
This property will be considered for inclusion into the next maintenance release, due out at the middle of next month.Quant wrote:Please let us know when we can get this functionality.
We have downloaded the latest release of .Net TeeChart, but we haven't found the resolution for this Blank Space Issue.This property will be considered for inclusion into the next maintenance release, due out at the middle of next month.
Please let us know where we can find the same.
- Guru
In the latest release notes we have:Quant wrote:We have downloaded the latest release of .Net TeeChart, but we haven't found the resolution for this Blank Space Issue.
This property can be used like this:
Candle series1;
series1 = new Candle(tChart1.Chart);
Random r = new Random();
double tmpOpen;
double tmpClose;
int count = 0;
DateTime dt = DateTime.Today;
TimeSpan ts = TimeSpan.FromDays(1);
for (int t = 0; t < 13; t++)
tmpOpen = r.Next(100);
tmpClose = tmpOpen - r.Next(100);
if (dt.DayOfWeek != DayOfWeek.Saturday & dt.DayOfWeek !=
DayOfWeek.Sunday)
++count;
series1.Add(dt, tmpOpen, tmpOpen + r.Next(50),
tmpClose - r.Next(50), tmpClose);
dt += ts;
private void checkBox1_CheckedChanged(object sender, EventArgs e)
series1.RemoveGaps = checkBox1.Checked;
Candle newSeries = new Candle();
newSeries.VertAxis = VerticalAxis.Right;
newSeries.UpCloseColor = Color.White;
newSeries.DownCloseColor = Color.Black;
newSeries.CandleWidth = 2;
newSeries.TreatNulls = TreatNullsStyle.Skip;
newSeries.Marks.Style = MarksStyles.Value;
newSeries.Marks.MultiLine = true;
newSeries.Title = "Title1";
for (int i = 0; i < chartObj.totalSampleValues; i++)
date = (DateTime)dataTable.Rows[i][0];
open = dataTable.Rows[i][1];
close = dataTable.Rows[i][2];
high = dataTable.Rows[i][3];
low = dataTable.Rows[i][4];
labels.Add(date.ToShortDateString());
closeValues.Add(close.ToString());
//newSeries.Add(i, open, high, low, close);
newSeries.Add(date, open, high, low, close);
//newSeries.Labels = labels;
newSeries.RemoveGaps = true;
this.tChart1.Series.Add(newSeries);
newSeries = (Candle)tChart1.Series[0];
Error comes at "newSeries.RemoveGaps = true;" this line.
Note: While in sample project this feature works as expected.
- Guru
Without access to your data, I'm afraid I cannot reproduce your issue. Can you please modify the code snippet below so I can reproduce your issue here?
Candle newSeries;
DateTime date = DateTime.Today;
double open, close, high, low;
Random rnd = new Random();
for (int i = 0; i < 20; i++)
date = date.AddDays(1);
open = rnd.NextDouble();
high = open + rnd.NextDouble();
close = high - rnd.NextDouble();
low = close - rnd.NextDouble();
//labels.Add(date.ToShortDateString());
//closeValues.Add(close.ToString());
if (date.DayOfWeek != DayOfWeek.Saturday & date.DayOfWeek !=
DayOfWeek.Sunday)
newSeries.RemoveGaps = !newSeries.RemoveGaps;
We are using a DataTable with Following FieldsWithout access to your data, I'm afraid I cannot reproduce your issue. Can you please modify the code snippet below so I can reproduce your issue here?
1] Date
2] Open
3] Close
4] High
5] Low
Our problem still continues with series.RemoveGaps property. It shows blank screen when set to "true".
- Guru
As per the instructions for posting in this forum, which you can read here, can you please provide a Short, Self Contained, Correct (Compilable), Example (explanation here) with which we can reproduce your problem.Quant wrote:Our problem still continues with series.RemoveGaps property. It shows blank screen when set to "true".
Thank you.
