2 Problems in new VCL vs old VCL 7.07
walter0316
Post by walter0316 » Wed Jul 29, 2015 1:42 pm
HI, in the old version 7.07 I could run following:
procedure TForm7.Button3Click(Sender: TObject);
  inherited;
  // Show 3D Gallery:
  with TFormTee3D.CreateChart(Self,Chart1) do
  try
    Align:=alNone;
    BorderStyle:=TeeBorderStyle;  // bsDialog
    Position:=poScreenCenter;
    PageControl1.ActivePage:=TabViews;
    PageControl1Change(PageControl1);
    ResetTab3D:=False;
    ShowModal;
  finally
    Free;
That is not working anymore. What can I do?
Secondly, I could change the source in the old Library that there is a STyle psInvRainbow.
In the new Lib there is also no Inverse Rainbow Style. How can I add it again?
Could you add this Style-feature to the next update?
Thanks a lot.
Walter
Re: 2 Problems in new VCL vs old VCL 7.07
Post by Narcís » Wed Jul 29, 2015 2:22 pm
Hi Walter,
walter0316 wrote: That is not working anymore. What can I do?
That was changed in the earliest v9 (aka v201x) development stage. Now you can do this:
  // Show 3D Gallery:
  with TFormTee3D.Create(Self) do
  try
    ThePanel:=Chart1;
    Align:=alNone;
    ResetTab3D:=False;
    ShowModal;
  finally
    Free;
walter0316 wrote: Secondly, I could change the source in the old Library that there is a STyle psInvRainbow.
I can not find psInvRainbow in our sources history, the only mention of it I find is from a customer at this forum as a custom palette suggestion. As suggested there you can create as a custom palette.
psRainbow palette being:
  RainbowPalette:Array[0..24] of TColor=
    $000099,
    $0000C3,
    $0000EE,
    $001AFF,
    $0046FF,
    $0073FF,
    $009FFF,
    $00CBFF,
    $00F7FF,
    $08F4E3,
    $11E7C3,
    $1BDAA3,
    $25CD83,
    $2EC063,
    $38B342,
    $42A622,
    $4B9A02,
    $6A870C,
    $8A751A,
    $AA6328,
    $CB5036,
    $EB3E44,
    $FF2A61,
    $FF1596,
    $FF00CC
and code creating psRainbow below, will probably help you creating it.
  procedure SetRainbowPalette;
    // Special case, internal Rainbow palette is in VCL format:
    {$IFDEF FMX}
    function InvertColor(const AColor:TColor):TColor;
      with TRGBA(result) do
        Red:=TRGBA(AColor).Blue;
        Green:=TRGBA(AColor).Green;
        Blue:=TRGBA(AColor).Red;
        // FMX opacity is inverted from VCL:
        if TRGBA(AColor).Alpha=0 then
           Alpha:=255;
    {$ENDIF}
  var t : Integer;
    if Assigned(ParentChart) then
      // Wish: Instead of using "Length(RainbowPalette)" here use: NumSteps.
      // ie: Needs to calculate "middle" colors in between
      // if the NumSteps is bigger than 25.
      SetLength(ParentChart.ColorPalette,Length(RainbowPalette));
      for t:=0 to High(RainbowPalette) do
          ParentChart.ColorPalette[t]:={$IFDEF FMX}InvertColor{$ENDIF}(RainbowPalette[t]);
      // Default:
      for t:=0 to NumSteps-1 do
          DoAddPalette(tmpMin+ScaleValue*t,ParentChart.GetDefaultColor(t));
      ParentChart.ColorPalette:=nil; // should be OLD palette !!
walter0316 wrote: Could you add this Style-feature to the next update?
I added it to the wish-list (ID1259) to be considered for inclusion in future releases.
walter0316
Post by walter0316 » Wed Jul 29, 2015 3:01 pm
Thanks a lot! I will try it tomorrow! :D
walter0316
Post by walter0316 » Wed Jul 29, 2015 3:30 pm
ParentChart is not known. What I have to do?
thanks
walter0316
Post by walter0316 » Wed Jul 29, 2015 3:47 pm
Is it correct, when I define PartenChart as my Chart1?
More Q:
WHen I define a User Palette. WHat must I define for MPISeries.PaletteStyle?
walter0316
Post by walter0316 » Wed Jul 29, 2015 3:48 pm
I have doen this:
  with MPISeries do
      PaletteSteps := 24;
      //PaletteStyle := psInvRainbow; InvRainbow wäre richtig, doch nicht im neuer Lib
      //PaletteStyle := psRainbow;
      SetINvRainbowPalette(Chart1);
      //StartColor := 8404992;
      StartColor := clGreen;
      UseColorRange := False;
      UsePalette := True;
      UsePaletteMin := True;
      PaletteStep := Lipo9Satz.MPiMAX / 23;
walter0316
Post by walter0316 » Wed Jul 29, 2015 3:55 pm
Hey, I found in the EDIT CHART Window an INVERT BUtton!!! I think I can use this for inverting the Rainbow and then it is defined as user pallete. right?
walter0316
Post by walter0316 » Wed Jul 29, 2015 6:55 pm
I get an ACCESS VIALOTION after SHOWMODAL!!
Could you reproduse this? Please help.
  //inherited;
  // Show 3D Gallery:
  try
    ThePanel:=Chart1;
    Align:=alNone;
    ResetTab3D:=False;
    ShowModal;
  finally
    Free;
(*      problem in new vcl
  // Show 3D Gallery:
  try
    Align:=alNone;
    ResetTab3D:=False;
    ShowModal;
  finally
    Free;
Post by Narcís » Thu Jul 30, 2015 7:57 am
walter0316 wrote:Is it correct, when I define PartenChart as my Chart1?
This is at series level, it should be series' ParentChart property, for example:
Chart1[0].ParentChart
walter0316 wrote:WHen I define a User Palette. WHat must I define for MPISeries.PaletteStyle?
Nothing. You should define your custom palette as in the example here or the example at All Features\Welcome!\Chart Styles\Extended\Contour\Palette and Color range in the new features demo, available at TeeChart's program group.
Post by Narcís » Thu Jul 30, 2015 8:01 am
walter0316 wrote:Hey, I found in the EDIT CHART Window an INVERT BUtton!!! I think I can use this for inverting the Rainbow and then it is defined as user pallete. right?
Where did you found that exactly?
Post by Narcís » Thu Jul 30, 2015 8:04 am
walter0316 wrote:I get an ACCESS VIALOTION after SHOWMODAL!!
No, I can't reproduce it. Which Delphi version are you using? Can you please attach a simple example project we can run "as-is" to reproduce the problem here?
walter0316
Post by walter0316 » Thu Jul 30, 2015 8:22 am
You can find the INVERT BUtton on the
Edit Chart by clicking on the chart and then select the Series and then see my attached Screenshoot.
You just have to select Rainbow and then click on INVERT button.
walter0316
Post by walter0316 » Thu Jul 30, 2015 8:44 am
here I have done a sample with the ACCESS VIOLATION. I use Delphi XE6 with the latest VCL Teechart.
bug_ACCESS_VIOLAT.zip
source only, EXE is 5MB to large for uplaod
(56.88 KiB) Downloaded 1304 times
Post by Narcís » Thu Jul 30, 2015 10:01 am
walter0316 wrote: Edit Chart by clicking on the chart and then select the Series and then see my attached Screenshoot.
Excellent! Chart editor is so extensive... :wink:
Post by Narcís » Thu Jul 30, 2015 10:30 am
Hi Walter,
walter0316 wrote:here I have done a sample with the ACCESS VIOLATION. I use Delphi XE6 with the latest VCL Teechart.
Sorry, my bad, I was not choosing any options in the editor. I have added it (Bug #1260) to the bug list to be fixed for future releases.
