hi,
On a canvas, I set for the LeftAxis and BottomAxis axes, a Grid with psDash
BottomAxis.Grid.Style = psDash
If I print with Monochrome option, the grid appears as a straight line.
Can one control the interspace for the Dash, and if so which option shall I use here?
Many thanks for your valuable help
Monochrome option and psDash interspace
thanks,
Nabil Ghodbane (PhD. Habil)
Re: Monochrome option and psDash interspace
Hello Nabil,
I've made a simple example printing a chart to a virtual pdf printer and I can see the dashed style in the bottom axis grid.
Here the code:
And here the pdf I get:
Here the code:
uses Series, TeeEdiGene;
Chart1.Monochrome:=true;
ChartPreview(nil,Chart1);
Chart1.Monochrome:=false;
Chart1.Legend.Visible:=false;
Chart1.AddSeries(TBarSeries).FillSampleValues;
Chart1.Axes.Bottom.Grid.Style:=psDash;
hi Yeray,
many thanks for your reply.
I certainly did not describe accurately the issue I have to deal with here and which is illustrated on the attached plot on which I need to have a grid.
My point is to know whether one can control the dashes frequency aka the gap between two consecutive dashes of one grid line.
basically, can one go from:
to (a larger gap)
Is this supported at all? I had a careful look at the Grid properties, but did not come to any improvement.
Note that, the file is saved as WMF (If I use BMP, the plot quality is worse)
thanks!
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
thanks!
- Capture.PNG (55.52 KiB) Viewed 8194 times
thanks,
Then, this looks related to this feature request.
I'd suggest you to add your mail to the CC list to be automatically notified when an update arrives.
