Chaging Titles of Teechart Forms
Seveno Developer
Post by Seveno Developer » Fri Nov 20, 2015 3:40 am
Hello team,
Similar to that of the Chart Editor, are we able to change titles of the series gallery form and export form? - Screenshots attached. If we can, what is the approach? Please suggest.
Thanks in advance
Kind regards
Khaled
Export
Series Gallery
Re: Chaging Titles of Teechart Forms
Post by Christopher » Mon Nov 23, 2015 8:47 am
Hello Khaled,
Yes, I think there's an example of what you're looking for in the Feature demo under:
%ProgramFiles(x86)%\Steema Software\Steema TeeChart for .NET 2015 4.1.2015.08060\Examples\DemoProject\bin\ExecutableDemo\TeeChartNetExamples.exe
in:
All Features -> Welcome !\Components\ChartController\ChartController Editor
Seveno Developer
Post by Seveno Developer » Mon Nov 23, 2015 10:27 pm
Hi Christopher,
Thanks for replying.
I've seen the examples. We're currently not subscribed for 100% source code (planning to move).
I was just wondering is it doable from our application at runtime without having teechart source?
Khaled
Post by Christopher » Tue Nov 24, 2015 8:33 am
Hello Khaled,
Seveno Developer wrote: I've seen the examples. We're currently not subscribed for 100% source code (planning to move).
Yes, you do not need the TeeChart source code to implement this functionality. The examples I pointed you to do not use the TeeChart source code but only the TeeChart assembly (*.dll).
Seveno Developer
Post by Seveno Developer » Tue Nov 24, 2015 11:46 pm
Hi Christopher,
Sorry but I am not being able to get which part of the code in the example sets the title of my Desired Forms?
As I already have mentioned, I am able to set the title of the editor, Hide and display tabs under the editor but my aim is to change title "Tee Chart Gallery" and "Tee Chart Export" (As Attached Screenshots in the first comment).
Could you please specify
Thanks and regards
Khaled
Post by Christopher » Wed Nov 25, 2015 1:17 pm
Hello Khaled,
The example I mentioned gives you something like this:
So, using the following code:
    Editor editor1;
      editor1 = new Editor(tChart1);
      editor1.DefaultTab = Steema.TeeChart.Editors.ChartEditorTabs.Export;
      editor1.Title = "Insert your Custom Title here";
    private void button4_Click(object sender, EventArgs e)
      editor1.ShowModal();
will give you this:
Of course you can instantiate each form "manually" like this:
      Steema.TeeChart.Editors.Export.ExportEditor form = new Steema.TeeChart.Editors.Export.ExportEditor(tChart1.Chart);
      form.Text = "My Title";
      form.ShowDialog();
which gives:
Seveno Developer
Post by Seveno Developer » Thu Nov 26, 2015 1:31 am
Hi Christopher,
We can instantiate the context forms but how do we handle the event when it is accessed from the chart editor?
Our users are able to change series type or add a new series from the chart editor.
As an example, please follow these steps:
1. From chart editor, click on Series Tab
2. Click on Add tab
3. Form opens with title "Tee Chart Gallery"
(Screenshot attached)
Thanks and regards
Khaled
Post by Christopher » Thu Nov 26, 2015 9:19 am
Hello Khaled,
In your first post to this thread you posted two attachments, one of the Export Editor and one of the TeeChart Gallery. I trust that you now see that the case of the Export Editor has been resolved by the code I've sent you. The case of the TeeChart Gallery is different - unfortunately, as you correctly say, the only way to change the text on this dialogue is using the source code.
Seveno Developer
Post by Seveno Developer » Thu Nov 26, 2015 9:33 pm
Hi Christopher,
You're correct. We were able to change the export's title using the code for instantiating it outside the chart editor.
Only one that we're left with is the gallery. However, we're thinking of upgrading our subscription which, I believe, will solve our problem.
Thanks heaps for your help once again!
Khaled
