The following codes are OK for TLineChart, but they do not work for TPolarChart.
if OpenDialog1.Execute then
TheChart.BackImageInside := True;
TheChart.BackImage.LoadFromFile(OpenDialog1.FileName);
For TPolarChart , how to fill THE CIRCLE AREA with a picture?
Best Regards
How to fill the circle area with a picture for TPolarChart?
Re: How to fill the circle area with a picture for TPolarChart?
I've filed the issue to the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=1417
As you'll see I've also found a workaround for it and I've also fixed it for the next maintenance release.
When assigning a BackImage or Gradient, how to make THE CIRCLE AREA transparent or not?
- xxxxx.jpg (330.91 KiB) Viewed 10757 times
This seems to work fine for me:
Don't hesitate to let us know if you still find problems with it.
uses TeePolar;
var i: Integer;
Chart1.View3D:=false;
Chart1.Legend.Visible:=false;
Chart1.Title.Visible:=false;
Chart1.Gradient.StartColor:=RGB(240, 125, 20);
Chart1.Gradient.MidColor:=RGB(150, 10, 240);
Chart1.Gradient.EndColor:=RGB(200, 183, 225);
for i:=0 to 1 do
with Chart1.AddSeries(TPolarSeries) as TPolarSeries do
FillSampleValues;
Pointer.Visible:=false;
Brush.Clear;
Pen.Color:=Color;
Pen.Width:=2;
CircleBrush.Clear;
“Fill” is to fill Gradient or Picture.
“Inside” is to fill Gradient or Picture in THE CIRCLE AREA, Otherwise to fill THE CHART PANEL.
When “Inside” checked, it does not work as I expected. Would you like to test and correct it for me?
Best regards
Best regards
- Example.zip
- (58.84 KiB) Downloaded 576 times
I'm sorry, the workaround wasn't correct. The good one is to clear CircleBrush. Ie, in your test application:sripe wrote:When “Inside” checked, it does not work as I expected. Would you like to test and correct it for me?
procedure TForm1.BitBtn2Click(Sender: TObject);
Chart1.BackImageInside := CheckBox8.Checked;
(ChartListBox1.SelectedSeries as TPolarSeries).CircleBrush.Clear;
Chart1.BackImage.LoadFromFile(OpenDialog1.FileName);
Yes, it works to load a Picture. But, how to change the Gradient of THE CIRCLE AREA? Thanks.
In your FormCreate, after clearing the CircleBrush, try assigning it a bsSolid TBrushStyle:
CircleBrush.Clear;
CircleBrush.Style:=bsSolid;
