TeeChart with ColorGrid series crashes when mouse is moved
Tero
Post by Tero » Thu Feb 25, 2016 7:28 am
Latest TeeChart2015.ocx: crash, latest TeeChart2014.ocx: works fine. Example program with source code and .tee file included which can be used to reproduce and debug the problem.
ColorGridGraph.zip
.tee file. Copy this file to the .exe folder.
(491.96 KiB) Downloaded 913 times
TeeTest.zip
Source code to reproduce the crash. Loads .tee file.
(88.11 KiB) Downloaded 876 times
Re: TeeChart with ColorGrid series crashes when mouse is moved
Post by Yeray » Fri Feb 26, 2016 12:57 pm
We could reproduce the problem here with your .tee file. Thanks for reporting it.
While we investigate the root of the problem, we've seen disabling the mouse events at least stops this error:
m_pChart1->SetEnabled(false);
Tero
Post by Tero » Tue Mar 01, 2016 7:10 am
Unfortunately disabling chart is not an option as we use mouse notifications from chart in our implementation.
Post by Yeray » Fri Mar 04, 2016 12:48 pm
We could reproduce the problem also in VCL thanks to your tee file so I added it to the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=1456
