How to use custom labels in TpolarSeries?
Using TPolarSeries in TeeChart 2015, how to replace the original circleLabels at 0, 90, 180, 270 degrees with custom labels?
Re: How to use custom labels in TpolarSeries?
You can use the TPolarSeries' OnGetCircleLabel event for that. Ie:
procedure TForm1.PolarGetCircleLabel(Sender:TCustomPolarSeries; const Angle:Double;
Index:Integer; var Text:String);
if Text='40°' then
Text:='this was 40°';
Yes, it works. When Series1 exists, we can use the following procedure:
procedure TForm1.Series1GetCircleLabel(Sender: TCustomPolarSeries; const Angle: Double; Index: Integer; var Text: string);
if Text = '40°' then
Text := 'This was 40°';
But, if I create Series dynamically with codes, where to add and how to use the GetCircleLabel procedure? Would you like to give me an example?
Xiushan
Xiushan
To assign an event at runtime you just have to declare the method at the top, as the others. Note the method needs to declare the same parameter types than the event expects. Then, you can assign the event to the series. Ie:
private
{ Private declarations }
procedure Series1GetCircleLabel(Sender: TCustomPolarSeries; const Angle: Double; Index: Integer; var Text: string);
with Chart1.AddSeries(TPolarSeries) as TPolarSeries do
FillSampleValues;
OnGetCircleLabel:=Series1GetCircleLabel;
How to display Axis Labels at every Ticks?
Although I change the Label’s style and margins as far as possible, the Axis Labels do not display as crowded as expected (they are too sparse or few).
- www.jpg (56.57 KiB) Viewed 10117 times
- w2.jpg (59.62 KiB) Viewed 10116 times
- w1.jpg (59.3 KiB) Viewed 10122 times
You can modify the Increment:
However, if there isn't space for all the labels to be drawn, the circular grid will be drawn according to that Increment but the labels won't match.
In that case, you try setting a smaller font. Ie:
GetVertAxis.Increment:=200;
Chart1.Axes.Bottom.LabelsFont.Size:=7;
Chart1.Axes.Top.LabelsFont.Size:=7;
It seems that the labels arrangement on the BottomAxis not only relate to the BottomAxis component properties, but also relate to the CircleLabels properties. Sometimes, changing GetVertAxis.Increment or LabelsFont.Size do not get satisfied results. Generally, we expect to arrange the labels on the radial axes and the Radar/Polar circle, respectively. That is to say, the label’s properties on the radial axes and the Radar/Polar circle may be different. Do you have any good solutions to arrange the labels on the radial axes closely? Thanks a lot.
If I understand the problem correctly, you can use custom labels to manually place the labels you want. Ie:
uses TeePolar;
var i, tmp, tmpInc: Integer;
Chart1.View3D:=false;
Chart1.Legend.Visible:=false;
Chart1.Gradient.Visible:=false;
FillSampleValues;
Pointer.Visible:=false;
Brush.Clear;
Pen.Color:=Color;
CircleBrush.Clear;
Chart1.Draw;
with Chart1.Axes.Top do
tmpInc:=Round((Chart1[0].MaxYValue-Chart1[0].MinYValue)/5);
Items.Clear;
for i:=0 to 4 do
tmp:=Round(Minimum+(i*tmpInc));
Items.Add(tmp, IntToStr(tmp));
