Space between bar series
wakewakeup
Post by wakewakeup » Thu Mar 03, 2016 8:28 am
I have just upgraded teechart from a 2 years old version, and it is shown different for bar series.
I attached two charts, one is how it was seen in the previous version, and the other with the bars over other bars.
How can I configurate the distance between bars?
Re: Space between bar series
Post by Christopher » Thu Mar 03, 2016 9:50 am
wakewakeup wrote: I have just upgraded teechart from a 2 years old version, and it is shown different for bar series.
Would you be so kind as to post here a "Short, Self Contained, Correct (Compilable), Example" of the code used to generate the images and also the two version numbers of TeeChart.dll in which the difference can be seen?
Thank you.
wakewakeup
Post by wakewakeup » Tue Apr 12, 2016 9:55 am
Please find attached the example.
You can change the variable numberofvalues from 2 to 3 and see how if you have 3 values it is show with spaces and with 2 they are one over other. I would like to be always like the 3 values example.
TestTeechart.zip
(16.9 KiB) Downloaded 715 times
Post by Christopher » Tue Apr 12, 2016 1:38 pm
Thank you for your example.
I think you should be able to use the BarWidthPercent property to change this behaviour, e.g.
      int numberofvalues = 2;
      for (int i = 0; i < numberofvalues; i++)
        Steema.TeeChart.Styles.Bar barra = new Steema.TeeChart.Styles.Bar(chart.Chart);
        barra.BarWidthPercent = 60;
        for (int j = 0; j < numberofvalues; j++)
          barra.Labels[j] = "Label " + j.ToString();
          barra.Add(j, j * 10 + 1);
