Bottom and Custom Vertical Axis Label Start Position
Re: Bottom and Custom Vertical Axis Label Start Position
Hi Christopher,
I have requirement to disable anti aliasing. I have tried below code.
WebChart1.Chart.Aspect.SmoothingMode = System.Drawing.Drawing2D.SmoothingMode.None;
However, it is not working in my case. Please assist.
- Guru
Here is the code I am using with the latest version of TeeChart.dll:Priyanka wrote: I tried it but no luck.
and this is the result:
Thanks Christopher.
It removed extra borders. However, I need top and right border to only chart area as attached.
- Trend.png (203.47 KiB) Viewed 18321 times
- Guru
This code: gives me this result, without the borders you mention:Priyanka wrote:However, I need top and right border to only chart area as attached.
Hi Christopher,
I think you got confused. I need top and bottom border to only chart area.
- Guru
You might like to try the different variations in this code yourself until you come across the combination that most adapts to your needs:
WebChart1.Chart.Panel.Gradient.Visible = false;
WebChart1.Chart.Panel.Color = Color.White;
WebChart1.Chart.Panel.Bevel.Inner = Steema.TeeChart.Drawing.BevelStyles.None;
WebChart1.Chart.Panel.Bevel.Outer = Steema.TeeChart.Drawing.BevelStyles.None;
WebChart1.Chart.Aspect.View3D = false;
WebChart1.Chart.Series.Add(typeof(Line)).FillSampleValues();
//#1
//WebChart1.Chart.Walls.Visible = false;
//WebChart1.Chart.Axes.Visible = false;
//#2
//WebChart1.Chart.Walls.Back.Gradient.Visible = false;
//WebChart1.Chart.Walls.Back.Color = Color.White;
//WebChart1.Chart.Walls.Back.Pen.Color = Color.Red;
//WebChart1.Chart.Axes.Left.AxisPen.Visible = false;
//WebChart1.Chart.Axes.Bottom.AxisPen.Visible = false;
//#3
WebChart1.Chart[0].VertAxis = VerticalAxis.Both;
WebChart1.Chart[0].HorizAxis = HorizontalAxis.Both;
WebChart1.Chart.Axes.Top.AxisPen.Color = Color.Yellow;
WebChart1.Chart.Axes.Top.Labels.Visible = false;
WebChart1.Chart.Axes.Right.AxisPen.Color = Color.Blue;
WebChart1.Chart.Axes.Right.Labels.Visible = false;
Thanks Christopher. I will try it.
Need your help to implement requirement of showing blank report. As per attached screenshot. We need to draw series for some date range and rest should be blank.
- BlankChart.png (283.33 KiB) Viewed 18285 times
- Guru
Can you not simply set the bottom Axis's SetMinMax to a relevant value? Or is the situation more complex than this? If so, how?Priyanka wrote:Need your help to implement requirement of showing blank report. As per attached screenshot. We need to draw series for some date range and rest should be blank.
Hi Christopher,
SetMinMax function doesn't work. Below is the code I am using. However, it is not setting minimum to 0.2 and maximum to 200.
WebChart1.Chart[0].CustomVertAxis.Automatic = false;
WebChart1.Chart[0].CustomVertAxis.SetMinMax(0.2, 200);
WebChart1.Chart[0].CustomVertAxis.Labels.ValueFormat = "##0.##;{##0.##}";
Value format is also set. Not sure why the SetMinMax function is not working.
Need urgent help. Thanks.
- Guru
Hello!
This code:
gives me the following (depending on the random values of FillSampleValues, of course):
This code:
protected void Page_Load(object sender, EventArgs e)
Chart chart = WebChart1.Chart;
chart.Aspect.View3D = false;
chart.Series.Add(typeof(Line)).FillSampleValues();
chart.Panel.MarginLeft = 30;
Axis axis = chart.Axes.Custom.Add();
axis.Horizontal = false;
axis.RelativePosition = -40;
axis.PositionUnits = PositionUnits.Percent;
axis.SetMinMax(200, 300);
chart[1].CustomVertAxis = axis;
Hi Christopher,
Please taka a look in the attached code.
Appreciate quick help.
- SetMinMax.zip
- (63.83 KiB) Downloaded 616 times
Hi Christopher,
Any updates on the issue?
- Guru
This is the result of running the code you sent:Priyanka wrote:Hi Christopher,
I'm afraid to say that I'm not entirely sure what the issue is you refer to. Could you please be more specific?
Hi Christopher,
Attached is the output of the code shared by me. Not sure why the below code is not working in case of custom vertical axis
WebChart1.Chart[0].CustomVertAxis.SetMinMax(0.3, maxvalue);
Also, need inputs on setting chart resolution and exporting chart in binary format.
Appreciate your help.
- TrendMinMax.png (172.92 KiB) Viewed 18219 times
- Guru
It is working here. This code:Priyanka wrote:Hi Christopher,
WebChart1.Chart[0].CustomVertAxis.SetMinMax(maxvalue - (maxvalue / 10), maxvalue);
What help do you need, exactly?Priyanka wrote: Also, need inputs on setting chart resolution and exporting chart in binary format.
