Animations with label and percent error
jars
Post by jars » Thu Jun 02, 2016 2:27 pm
I bought the TeeChart pro version for delphi 7. When I want to animate a pie chart with label and percent values showing each portion are erroneous. The same applies to bar series, however if the sample values show well. See the attachment!
I would also like to know the version I sign says "TRIAL" if I have com meadow (TeeChart Pro v2015.14.150120 trial)?
And every time when modify a chart show error message "property detail not found"
Sin título.png (22.06 KiB) Viewed 8051 times
Re: Animations with label and percent error
Post by Yeray » Thu Jun 02, 2016 2:52 pm
I've tried to reproduce the problem with this code but it seems to give me a correct percentage in the legend:
uses Series, TeeDonut;
  with Chart1.AddSeries(TDonutSeries) as TDonutSeries do
    AddPie(2185.85, 'Promotores');
    AddPie(1236.47, 'Pasivos');
    AddPie(662.83, 'Detractores');
  Chart1.Legend.TextStyle:=ltsRightPercent;
jars wrote:I would also like to know the version I sign says "TRIAL" if I have com meadow (TeeChart Pro v2015.14.150120 trial)?
If you mean in the aboutbox, this is a known issue we corrected in further releases.
jars wrote:And every time when modify a chart show error message "property detail not found"
jars
Post by jars » Fri Jun 03, 2016 4:06 pm
Hi Yeray.
In the ErrorExample.zip attachment is the example that show after play animate button, labels percent always show 100%
In the ErrorImages.zip attachment are printscreens with the errors that was commented.
Jorge
ErrorImages.zip
Images that show errors
(158.38 KiB) Downloaded 496 times
ErrorExamplet.zip
Sample project
(505.16 KiB) Downloaded 521 times
Post by Yeray » Mon Jun 06, 2016 8:42 am
Thanks to your test application I could reproduce the problem with TeeChart v2015.14. I could also reproduce the problem with v2015.15.
However, it seems to work fine from 2015.16 and up. So I'd suggest you to update to the latest version available, v2016.18.
jars
Post by jars » Mon Jun 06, 2016 6:48 pm
This version 2016.18 is valid for Delphi 7? It not appears as option?
Post by Yeray » Tue Jun 07, 2016 7:10 am
From the v2016.18 TeeChart supports Delphi 7 only in the source code version. You'll find it in the "legacy" group.
