Eskimo
Post
by Eskimo » Thu Aug 18, 2016 8:16 am
There is only one half of the graph in the exported image when first a pdf and immediatly after a png image is exported.
The exported pdf is right, but the png is drawn incorrectly. TeeChart .net version 4.1.2016.5122
Incomplete Graph of the png image:
- IncompleteGraph.png (54.29 KiB) Viewed 4994 times
The graph should lik this
Complete Graph of the png image:
- Graph.png (152.69 KiB) Viewed 4990 times
Code snippet:
Steema.TeeChart.Export.PDFFormat pdf = MyTeeChart.Chart.Export.Image.PDF;
pdf.Height = 1062;
pdf.Width = 1889;
pdf.Save(filename + ".pdf");
Steema.TeeChart.Export.PNGFormat png = MyTeeChart.Chart.Export.Image.PNG;
png.Height = 1062;
png.Width = 1889;
png.Save(filename + ".png");
Best regards
T. Harder
- Guru
Post
by Christopher » Thu Aug 18, 2016 11:29 am
A call to TChart.Draw() resolves the problem, e.g.
private void button4_Click(object sender, EventArgs e)
string filename = @"D:\tmp\probexport1";
Steema.TeeChart.Export.PDFFormat pdf = tChart1.Export.Image.PDF;
pdf.Height = 1062;
pdf.Width = 1889;
tChart1.Draw();
Steema.TeeChart.Export.PNGFormat png = tChart1.Export.Image.PNG;
png.Height = 1062;
png.Width = 1889;
