DonutSeries
n2n
DonutSeries
Post by n2n » Fri Aug 19, 2016 6:37 am
I try to use DonutSeries with style like https://www.steema.com/uploads/products/Pie_Chart.png
but still ineffectual. Is it possible?
Re: DonutSeries
Post by Marc » Mon Aug 22, 2016 12:14 pm
Yes, use SliceHeight to vary heights.
Eg.
series1.FillSampleValues();
Series1.SliceHeight[0]:= 1000;
n2n
Re: DonutSeries
Post by n2n » Wed Aug 24, 2016 11:48 am
Ok thanks and one question more. So we have Hover with redline, How I can change redColor to some else color
n2n
Re: DonutSeries
Post by n2n » Thu Aug 25, 2016 6:23 am
When I pass data (2,1,1,15) to DonutSeries looks not expected. Here is example
How I can fix it?
DonutSeries.rar
(11.67 KiB) Downloaded 822 times
Re: DonutSeries
Post by Yeray » Fri Aug 26, 2016 10:20 am
n2n wrote:So we have Hover with redline, How I can change redColor to some else color
You can change this property:
Chart1.Legend.Selected.Hover.Font.Color:=clBlue;
n2n wrote:When I pass data (2,1,1,15) to DonutSeries looks not expected.
I'm afraid I have to confirm this is a well known and difficult to solve problem with the TPieSeries in some situations.
It's not a trivial problem that would probably need a complete redesign of the series to be fixed.
The only workaround I can think on at the moment is to change the rotation of the pie:
DonutSeries1.RotationAngle:=50;
http://bugs.teechart.net/show_bug.cgi?id=935
http://bugs.teechart.net/show_bug.cgi?id=939
n2n
Re: DonutSeries
Post by n2n » Mon Aug 29, 2016 7:22 am
hi Yeray
it is no solution in my case cause we have timer with
DonutSeries1.Rotate(358);
anyway there are few pic with bags You should to fix them
thanks.
Re: DonutSeries
Post by Yeray » Mon Aug 29, 2016 10:09 am
Note OpenGL gives a better result. Ie:
n2n
Re: DonutSeries
Post by n2n » Fri Sep 23, 2016 6:39 am
Ok thanks. Can you give some example please?
Re: DonutSeries
Post by Yeray » Fri Sep 23, 2016 7:41 am
n2n wrote:Can you give some example please?
I took your example form here.
uses TeeGLCanvas;
  //Activate OpenGL
  Chart1.Canvas:=TGLCanvas.Create;
  Chart1.Aspect.Elevation:=40;
  //Show Pen to better see the slices
  DonutSeries1.Pen.Visible:=true;
  //Make the Pen thinner
  Chart1.Draw;
  DonutSeries1.PiePen.Width:=0;
I also added this
