Horizontal Scrolling and Overflow
XamarinProgrammer
Post by XamarinProgrammer » Thu Sep 01, 2016 11:46 am
Hi I'm hoping anyone can help me.
I have created a chart with three bars and I'm displaying a number of grouped data into the three bars. Right now I'm able to show this graph:
Based on the documentations, scrolling in both directions is there by default however I am unable to scroll the data both vertically and horizontally. The chart is trying to fit everything on the frame.
Is there away to not let the chart fit all the data in the frame and just let it overflow horizontally and most importantly allow the user to scroll horizontally?
Please see my code:
private void SetupChart ()
	_chart = new TChart();
	_chart.Header.Visible = false;
	_chart.Frame = new CGRect(0, 0,
	                          GraphContainer.Frame.Size.Width,
	                          GraphContainer.Frame.Size.Height);
	GraphContainer.AddSubview(_chart);
	bar1 = new Bar();
	bar1.Title = "Oranges";
	bar1.Marks.Visible = false;
	bar2 = new Bar();
	bar2.Title = "Apples";
	bar2.Marks.Visible = false;
	bar3 = new Bar();
	bar3.Title = "Grand Total";
	bar3.Marks.Visible = false;
	_chart.Series.Add(bar1);
	_chart.Series.Add(bar2);
	_chart.Series.Add(bar3);
	_chart.Legend.CheckBoxes = true;
	_chart.Axes.Left.Grid.Visible = false;
	_chart.Legend.Alignment = LegendAlignments.Bottom;
	_chart.Legend.MaxNumRows = 3;
	_chart.Zoom.Active = true;
	_chart.Panning.Allow = ScrollModes.None;
	_chart.Zoom.Direction = ZoomDirections.Horizontal;
	/ Add data
	foreach(Data d in _datas)
		_bar1.Add(d.Orange, d.VendorName);
		_bar2.Add(d.Apple, d.VendorName);
		_bar3.Add(d.Orange + d.Apple, d.VendorName);
I tried looking over the samples inside the source codes, however the samples there are too simple and too few.
Hope somebody can help or just point me to the right direction
Thanks! :D
Re: Horizontal Scrolling and Overflow
Post by Pep » Thu Sep 01, 2016 12:39 pm
sure, notice that in the code you've set :
In order to allow the user just to scroll horizontally you should do :
            tChart1.Panning.Active = true;
            tChart1.Panning.Allow = ScrollModes.Horizontal;
In the case you want to show just some part of data in the frame you can set a specific points per page number, or set the desired min and max by using the following code :
           tChart1.Page.MaxPointsPerPage = 10;
           // or
           tChart1.Axes.Bottom.SetMinMax(10, 20);
XamarinProgrammer
Post by XamarinProgrammer » Fri Sep 02, 2016 2:35 am
Hi was able to limit data by applying the code you gave:
// or
and also applied:
Although it is correctly showing me the correct number of data in 1 page.. I'm still unable to scroll horizontally to the next page.
Do I need to handle scrolling to the next and previous pages manually?
Post by Pep » Fri Sep 02, 2016 6:17 am
Which TeeChart version are you using, TeeChart for Xamarin.Forms or TeeChart for Xamarin.iOS?
Does this happens with the latest version available on our website?
XamarinProgrammer
Post by XamarinProgrammer » Fri Sep 02, 2016 7:40 am
I am using the latest version of Xamarin.iOS
Post by Pep » Fri Sep 02, 2016 8:47 am
it's strange. I've just test it here and all seems to work fine.
Could you please check if the attached example is working fine for you ? It's a simple example which uses horizontal panning with points per page.
HorizPanning.zip
(9.68 KiB) Downloaded 1082 times
XamarinProgrammer
Post by XamarinProgrammer » Sat Sep 03, 2016 4:02 am
HI I run the project you gave me both on iPhone 6s Simulator 9.3 and actual iPhone 6s device with iOS 9.3
Both are not panning horizontally (left or right).
Please see screen recording https://www.dropbox.com/s/bs1p1mfsydi07 ... g.mov?dl=0
My version of TeeChart as written in the release notes:
Release Notes 20th Jun 2016
TeeChart.NET for iOS version 2016
Build 4.16.06.20
Post by Pep » Mon Sep 05, 2016 10:24 am
ok, I'm going to prepare a new dll compiled and send it directly to you so you can check if the problem persists with that one. I'll send it directly to your email account.
XamarinProgrammer
Post by XamarinProgrammer » Tue Sep 06, 2016 5:44 am
I have compiled the project that you gave me with the dll you sent and is now working fine. My original project is also now running ok with the new dll.
Thank you so much for your help. I'm not sure why the version I downloaded from your is not working as expected. Maybe I'll try out other versions later.
Again, thank you!
Cheers!
